Author Topic: Third Time Lucky - 750 Digger Chopper - this time I'll get it done  (Read 1695 times)
Offline spotty
I originally bought this frame over 30 years ago, along with the oil tank and seat.
After many years of looking at it and dreaming about what I was going to need, I realised I had neither the tools or skills to do any of it, so I sold it to a mate who had the same dreams and skill set, eventually he gave it back.
Move forward a few years and I sold it again to another mate who had the same plans, move forward another 15 years and it's mine again 👍
I swapped a pair of Abe wheels, full Dunstall body kit, Rickman fairing and some other stuff so he can commit to a less ambitious project with his sohc750.
Got it yesterday so today is mock-up and assess what needs doing and buying, and of course it's stinking hot ( about 100F in the measurements of the dead ) but I am a happy boy.
It'll get the 6" over swingarm I bought recently, Terry has an engine and crossover drag pipes that I can get off him.
The prism tank is on backwards, looks and fits better, it'll have the filler cap blanked off and a flush mounted mini one put in up the front, fuel tap hole will go to the back
The forks are hopefully going to be girders but by fxuk they're going to be long, about 1100mm from top triple to axle.
Seat will probably be cut down to a single and a recess at the front to access the oil tank
A while ago I got a pair of alloy rim wheels off Terry and now that I don't have the Abe's I'll use them
Bars will maybe be tiller style to get the pullback but still have a flat profile side to side.
I scored a digger back guard but I'll need something to fill the gap behind the seat
Got forward controls which I'll use to make templates for some heavy duty alloy ones.
I was going to lower the back end and use struts but that'll just make the front end longer and higher so it'll be alloy body Koni's or Fournales air shocks which don't have an external spring
Headlight will be mounted in the front of the frame to make it disappear, nice clean forks that way
Paint job will be 70's inspired in ( probably red/yellow/green)
Depending on what the frame looks like when it's stripped for weld assessment it could well be nickel plated
More later
i blame Terry
Offline Dime
Re: Third Time Lucky - 750 Digger Chopper - this time I'll get it done
« Reply #1 on: January 06, 2025, 04:04:30 PM »
This is going to be sick! Looking good. I like the way you have the tank mounted, very different.
Sent from my SM-S721W using Tapatalk
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: January 06, 2025, 07:39:34 PM »
Looks like fun!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #3 on: January 07, 2025, 06:42:50 AM »
Should be an interesting ride!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #4 on: March 15, 2025, 05:55:48 PM »
Updates?
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline spotty
« Reply #5 on: March 16, 2025, 04:55:13 PM »
Updates?
been trying for a week to load pictures and stuff off my phone, won't let me, i hate technology
there has been progress, but not for the poor little red frame, last weekend i caught up with a mate of terrys who sold me another frame, invader wheels, seat, reverse rocket tank and some other bits. the frame is a GME (general motorcycle engineering ) from the 70's. Made in california i believe
the XR forks i bought that were too short for the red frame but are just right for the new one. Terry is going to build me a motor for it, need to find some drag pipes or maybe use F2 headers as the have a higher flat profile under the engine, need as much clearance as possible cos its a very low frame
i'll keep trying to upload pics of it
i blame Terry
Offline CycleRanger
  • No comment about being an
« Reply #6 on: March 16, 2025, 05:59:08 PM »
And difficult to fill with more than a gallon when mounted that way.
Offline spotty
« Reply #7 on: March 16, 2025, 06:04:35 PM »
If this works then this is the new frame
those tyres will be goin and replaced with something a little more modern
« Last Edit: March 16, 2025, 06:08:50 PM by spotty »
i blame Terry
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #8 on: March 16, 2025, 07:19:30 PM »
I've been having trouble uploading pic on the website as well. I use taptalk to load photos makes it a lot easier.
Those GME frames are cool!
Love the vaders!!!!!
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #9 on: March 17, 2025, 04:53:04 AM »
I don’t remember gme making gooseneck frames. That might be a santee softail, or a machine shop frame.
Maybe check -> http://www.hondachopper.com/gallery_misc/frame_ads/frame_ads.html
Offline spotty
« Reply #10 on: March 17, 2025, 02:43:29 PM »
this is what made me think GME, looks the same including the oil tank and the plunger/soft tail parts, most others seem to have a centre pin that takes a nut on both ends, the GME has a large cap on the top that locks into the top of the plunger tube and a nut on the bottom
https://forum.chopcult.com/forum/nbsp/main-forum/19443-gme-general-motorcycle-engineering-co-frames
i blame Terry
  • Gusto mo titi ko?
    • project
« Reply #11 on: March 17, 2025, 03:07:41 PM »
Those plunger pieces were used by other companies too including jammer on their velvet ride
Offline spotty
« Reply #12 on: March 17, 2025, 04:16:08 PM »
cheers, i might find out for sure as i get it pulled apart
also as far as the registration authorities are concerned, its a stock honda frame.....
i blame Terry
Offline spotty
« Reply #13 on: March 19, 2025, 10:30:47 PM »
Going to do the twin carb thing on this, Terry kindly donated the manifolds to the project, got the adaptors yesterday, made sure they fitted and ordered carbs and bellmouths last night
i blame Terry
Offline spotty
« Reply #14 on: March 20, 2025, 03:49:35 PM »
And here are the fuel delivery devices, take them home and see if they fit now
i blame Terry
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #15 on: March 20, 2025, 04:58:07 PM »
I wonder how tuning those are compared to stock carbs.
Offline spotty
« Reply #16 on: March 20, 2025, 05:56:34 PM »
i just started a thread asking for advice on base line jetting and such
i blame Terry
Offline spotty
« Reply #17 on: March 21, 2025, 03:42:13 PM »
Carbs turned up yesterday, the tube thing in front is the throttle cable splitter ( off a BMW I think but don't tell anyone )
i blame Terry
Offline spotty
« Reply #18 on: April 02, 2025, 11:41:19 PM »
Now have manifolds ( from Terry ), carbs, new mixture screws that can be turned by hand instead of trying to get a screwdriver to the inaccessible one, clear float bowls and very unrestrictive bellmouths that will get filter foam inside. Much happy. Just got to set the jets and such
i blame Terry
Offline spotty
« Reply #19 on: April 02, 2025, 11:49:28 PM »
Billet points cover also turned up, $120 delivered, fecking bargain. Might get another on for the dirtbike
i blame Terry
Offline spotty
« Reply #20 on: April 03, 2025, 12:34:24 AM »
And one of these which may well go on the dirt bike and then I'll get another one for the chopper
i blame Terry
« Reply #21 on: April 03, 2025, 09:49:22 AM »
If you put filter foam inside those stacks it will restrict the hell out of them! You might as well stuff them with shop rags. ;)
Offline Dime
« Reply #22 on: April 12, 2025, 12:06:36 PM »
Some cool pieces going on this build. Gonna be cool
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #23 on: April 13, 2025, 07:37:40 AM »
It will be interesting to see how the 1-2, 3-4 carb pairing goes. I wonder if there will be any spit back.
1973 CB 750 K3
  • Gusto mo titi ko?
    • project
« Reply #24 on: April 13, 2025, 07:51:10 AM »
Good luck with them! Im a creature of habit and will stick to 1 carb per cylinder
