Author Topic: Who knows the origin of the dual output coil in a waisted ignition system?  (Read 706 times)
Offline Deltarider
  • I'm back
I happen to love simplicity. The more I have looked at our ignition sytem, the more I admire it. I've searched the internet but I have not found an answer yet. Who was the first who thought of it and what vehicle had it first? I have two candidates: carmaker Citroën and Harley-Davidson. Does any of you have the answer or can tip me where to look?
CB500K2-ED Excel black
Offline 69cb750
Harley used a single coil with two leads in the 20's
Indian used a single coil with one lead and distributor.
It was said to have come from the first shipboard "petrol-fueled" (i.e. early gasolines) engine designs of early internal-combustion types that ran at speeds like 600 RPM. I found that reference in a very old, tattered book about old airplane designs, read it around 1972 or so when I had just opened my shop. It was written by a British author, about British accomplishments. Danged if I remember the title, though... :(
These coils actually run opposite phases as they discharge: for example, if it was a 1-4 coil, when the spark starts it jumps from the plug tip to the ground on one side, and the opposite polarity (and direction) on the other plug. It oscillates between 3 and 6 times in our bike's versions, per oscilloscope traces I made back when I wrote my first book on the 750. It oscillates many more times than that, but without enough energy to jump the plug gap. The condensors help damp out the leftover energy then to allow for quicker recharge for the next time around.
Online scottly
The issue with a dual output coil is that one terminal produces an reverse polarity spark; with our stock coils, cylinders 1 & 2 always have the proper polarity, while 3 and 4 always have reverse polarity. A reverse polarity spark requires 20 to 40% more voltage than normal polarity.
BTW, the term is wasted, as in to throw away, not waisted, as in a person's middle torso.
« Last Edit: January 19, 2025, 08:50:42 PM by scottly »
 Scottly, have you ever seen a Gerex spark on an oscilloscope? If a stock coil oscillates between wires, I wonder what the Gerex actually does?
Offline rocket johnny
look up charles kettering ,,  he did a lot of work on coils and did the first electric starter
 Kettering was a busy boy. The electric cash register, freon, Deco automotive paint, some radio, a precursor to the credit card, Delco ignition systems, locomotive and heavy equipment propulsion, aerial torpedo, electric starter, 2 stroke lightweight diesels, leaded gasoline, etc.
He was a busy boy: I sometimes have wished his creations hadn't gone to GM, though. They have a sordid history of kitbashing and corrupting good things into something less. One of the worst was their 1980s-era "electronic ignition" for cars (it replaced points inside the distributor, much like the modern Prestolite) - they used the wrong type of semiconductor (MOSFET), so everything had to work at 100% all the time and the battery in the car could not drop below 12.1 volts or the unit would self-destruct. That's why so many of them that were popularly added to the CB500/550 worked for a week: that battery will frequently droop during electric starting. If the car had a weak battery, dropping to 10 volts during a cold winter's start, the same thing happened. By the thousands.
Offline Tracksnblades1
Read about Faraday…it’s his theory of induction that paved the way..I’m thinking another guy, Maxwell, was in there to with his equations…later came Testla with CD ignitions, that Henry Ford was credited using over here first..
Age Quod Agis
