Author Topic: Stuck black gasket problem solver  (Read 2450 times)
« on: January 21, 2025, 02:51:13 PM »
  I noticed that if I can lift any area of the gasket I can pry up with a scraper, put something under it to leave a little tension and walk away. The gasket will lift slowly and leave less stuck material behind.
  Then, when I have worked my way across the gasket and have it removed, I brushed a little of the newer safe paint stripper, (not even the good stuff) and it will quickly soften the outer layer of black gasket that was left behind.
  I use a gasket scraper that holds a utility knife blade, a few layers at a time and in a half hour the head was cleaned off.
 Now, into the solvent tank to remove the stripper residue. It's also removing a lot of carbon from the combustion chambers.
Offline BenelliSEI
  • 1969 cb750
Re: Stuck black gasket problem solver
« Reply #1 on: January 21, 2025, 03:09:26 PM »
I’ll try that!
Offline CycleRanger
  • No comment about being an
« Reply #2 on: January 21, 2025, 03:11:58 PM »
Yep, I have used paint stripper on old gaskets as well.
Offline Alan F.
« Reply #3 on: January 21, 2025, 06:40:38 PM »
I've had good luck with goof-off remover.
« Reply #4 on: February 03, 2025, 05:59:31 PM »
 I got thin layers with the paint stripper and began using a brass wire brush and stripper.
