Author Topic: CB550 rear wheel bearings removal  (Read 160 times)
Offline Peashooter
« on: January 24, 2025, 12:05:40 PM »
Getting ready to take out the old bearings, bearing retainer off. Manual says "drive out the bearings". ? Which side do you start with? Do you drive one bearing in until the other side falls out, the reverse it? There must be a method to this, and i don't want to break anything.
Offline Flyin900
Re: CB550 rear wheel bearings removal
« Reply #1 on: January 24, 2025, 12:46:48 PM »
Cheap method is apparently a concrete anchor inside the bearing hole expanded with a bolt until the anchor is snug and then driven out from the opposite side on the anchor face with a drift punch
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #2 on: January 24, 2025, 12:51:00 PM »
I  have always heated the hub up with a heat gun and they almost fall out. To install freeze the bearings and heat the hub up with a heat gun and they drop in!
1976 Z50A YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #3 on: January 24, 2025, 12:58:56 PM »
Circulat drift, tap the centre spacer sideways, drift out bearing both go outwards.
Always new bearings as you have to drift on inner race to remove.
Bearing retainer is LH thread, tight and drill out the stakings
Offline Cevan
« Reply #4 on: January 24, 2025, 01:47:58 PM »
I just did this on my 500.  I removed the bearing on the retainer side.  I just used a drift from the other side.  I am replacing them so I didn't care about hitting the inner race of the bearing.
Offline Peashooter
« Reply #5 on: January 25, 2025, 08:35:20 AM »
Thanks for the help, old bearings are out. Now to strip, clean and polish the hub before lacing up a new rim.
Offline Oddjob
« Reply #6 on: January 26, 2025, 07:38:45 AM »
The bearing under the retainer has a special spacer inserted into it, don’t throw that away with the old bearing. When you remove the retainer you must drive the brake side bearing out first, when that is removed you can then remove the central spacer and the special spacer. DO NOT drift onto the special spacer as it’s mild steel and distorts easily ruining it for future use. They are hard to find when ruined and expensive as well. There is someone in the UK making them in stainless if you need one.
The special spacer was fitted as the internal diameter of the retainer bearing was bigger than the wheel spindle Honda wanted to fit so they fitted this spacer to reduce the diameter to fit.
« Reply #7 on: January 30, 2025, 07:00:51 PM »
Is it me, or does that too-short spindle look like it came from a CB/CL350?
