750K1: Electrical changes from stock are Dyna-s and Dyna 5ohm coils, H4 headlight, truck horns run through a relay connected directly to battery, heated handgrips (not used much recently), and aftermarket blade-style fuse holder. All of these have been installed for at least two years.
Now for the gremlins!
With the headlight off, bike runs and idles fine. With headlight on, bike idles poorly and hesitates and sputters on initial accelleration, until it gets over 2K rpm, then it's fine.
So I'm thinking my battery is running down because it's fine over 2K when the charging system is making enough juice. Nope, hooked up charger, it's at 100%, electrolyte levels all full.
I disconnected the horns and the handgrips to narrow it down, still no change.
The only thing I did to the bike before this happened was remove the tank to polish up the valve cover for the bike's Spring cleaning. I checked all the wires and connections in that area to make sure I didn't snag something. All seems fine.
This happened very suddenly and during a time when the bike has been in regular use, so I don't think it's something that crept up slowly and I just didn't notice. This leads me to believe it's either a loose connection or short somewhere, but I can't find anything.
Any ideas? I'm going back out to the garage, but I'll check back in shortly.
