Author Topic: crankshaft bearing selection (no letters stamped and no colors)  (Read 2191 times)
Offline mazingerzeca
Hello all.
I'm rebuilding a cb 750 F2 engine, and I arrived to the crankshaft.
I have the tables for selecting the crankshaft bearings crossing the letters stamped on the crankcase and the letters stamped on the crankshaft. They would give me a color to order the replacement bearings. Well, I did not find any code stamped on the crankshaft where it was supposed to be. Is this possible or maybe that is an aftermarket crankshaft? I tried also to order the replacement bearings according to the color codes painted on the old bearings, but there were no color paint on them. Maybe they are also aftermarket bearings? I don't know the story of the bike, I own it since 2003.
Are the bearings the same for all F2 models or that tables are made because the bearings vary from engine to engine, even being all of them F2 engines? If I order a set of F2 bearings, will they fit or is it really necessary that color codes and that letters stamped that my crankshaft doesn't have?
Thank you.
Offline scunny
  • don't call me expert
Re: crankshaft bearing selection (no letters stamped and no colors)
« Reply #1 on: March 22, 2007, 11:50:32 AM »
not all crankshafts are stamped,I have 2 that aren't. the upper case should have 5 letters stamped on it to give you that end of the equation. failing that the only way I know is to get a couple of new bearings(say green) and then use plastigauge with them on each journal to find which bearings will be best.
hopefully someone who can explain this better will chime in.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #2 on: March 22, 2007, 01:57:16 PM »
Do these crankshaft come from a 750 F2 model? Are they aftermarket? Thank you
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #3 on: March 22, 2007, 04:30:23 PM »
Not that I've seen many cranks but I have yet to see one stamped. The ones I've seen have been hand scribbled on in a Japanese accented (if that makes sense) lettering. Looks like they could've taken a screw driver and marked it. You will probably need to take it out into the sunlight and move it around until you see what could be mistaken for light scratches near #2 or #3. The crank I recently pulled and sent to Big Jay at APE for balancing was marked: J-)L-AAAAA  P)L-4444. Real difficult to make out until you've done the first one. Keep in mind what range of letters you're looking for because you'll need to use your imagination a little to determine what the Japanese tech was attempting to write in English letters.
Offline dakeddie
« Reply #4 on: March 22, 2007, 08:21:49 PM »
Yup.. my crankshaft looked like the letters with written on with white pencil crayon.  Verrry difficult to read... also one letter I couldn't tell whether it was an A or a B cause of the chicken scratch.
Look really carefully on the flywheel where the manual says the letters are "stamped".
Offline rhinoracer
« Reply #5 on: March 22, 2007, 09:43:59 PM »
Mine's scribed in one of the counterbalancers too, you can barely read it. However you have to buy the bearings separately for each main, you can't buy them as a set unless all measure the same.
If you want the same size you can mic the original bearings which will not give you the right size since used bearings have wear.
You can also mic both the cases and the crank and use the tables to determine size.
You can use plastigage but this will only tell you if your actual bearings are within tolerance but not which color you should buy.
Baja native.
Offline Big Jay
    • CBRzone
« Reply #6 on: March 22, 2007, 10:15:56 PM »
Measure the journals and see what number they are.
Jay
« Reply #7 on: March 23, 2007, 02:13:01 AM »
To the best of my knowledge there is noone making aftermarket cranks or shells, Modified cranks yes---but they are Honda cranks to start with.
The markings, as said, are VERY difficult to see but they are there
« Reply #8 on: March 23, 2007, 04:40:15 AM »
Jay
You should measure them even if you can read the marks.
Offline Big Jay
    • CBRzone
« Reply #9 on: March 23, 2007, 10:35:23 PM »
Absolutely.  These cranks are 30 years old. The journals aren't necessarly the size of the code after all those miles.
Jay
« Reply #10 on: March 25, 2007, 06:13:25 AM »
After many years of looking i find that there are two types of Honda crank:-
(1) Those with no measurable wear from when manufactured
(2) Those that are only suitable for use as ballast or offensive weapons
Never yet found one somewhere in the middle!
« Reply #11 on: March 28, 2007, 12:27:36 PM »
Hello all.
I've checked the crankshaft but I did not find anything readable where the codes for replacing bearings should be.
But I've found something that can add some information to identify the crankshaft bearings. From alternator side, I've seen the following letters stamped on the crankshaft bearings:
- D7G STD
- D7G STD
- D7G STD
- D7H (the color seems to be green)
That's all the information I've got from the bearings. Given that the two bearings with a green color have the same code stamped, maybe the other codes mean another color? Do that codes mean anything related to bearing size?
Thank you
Offline scondon
  • Mmmm......tasty bugs
« Reply #12 on: March 28, 2007, 02:14:26 PM »
   Honda gets their bearings from several different manufacturers. The codes marked on your bearings might mean something to the manufacturer, but I don't think that they can be referenced by Honda. If you stand the bearings on the side you might be able to see a small color mark. Much like a green or yellow or brown pen mark.
   I've taken out two F2 cranks and neither one had markings on it. Even if you knew what color bearings were installed when new you really can't skip the step of measuring(plastiguage) with new bearings to see what you need for replacement, as others have stated above.
   If it were me, I would order two pairs of Yellow bearings for measuring purposes. Insert the new bearings in 2 of the 5 journals and put old bearings in the remaining three and plastigauge the new Yellow bearings. Then switch the Yellow bearings to different journals and repeat. This means you will have to torque down your crankcases three times to measure all five journals. Bwaller turned me on to this method and it was a real time/money saver.
    I ended up putting 4 black and 1 Yellow for my crank.
« Last Edit: March 28, 2007, 02:17:05 PM by scondon »
