Author Topic: removing a clutch (or how do you use this tool)  (Read 1872 times)
Offline rab1dwolf
« on: March 24, 2007, 09:36:00 PM »
ok so I'm taking a stab at removing my clutch since I never got it off last year.
My honda shop recommended and sold me a motion pro clutch holding tool.
it is a pair of vice grips with a 90 angle at the end and two little round peices on the backside.
heres a picture:
I have no idea how this thing is suppsoed to work.  I'm trying to get that stupid special nut off inside the clutch but the interrior just rotates freely.
any advice on how this thing is supposed to work would be greatly appreciated.
I'm going to try my new nifty air tools tomorrow and see if that helps as well
1982 cb650sc nighthawk.  the work never stops.
Offline mkramer1121
Re: removing a clutch (or how do you use this tool)
« Reply #1 on: March 24, 2007, 09:44:09 PM »
I'll let you know tomorrow night, were taking a look at my 750 clutch before we button the engine up...
Offline mrblasty
  • Expertly
« Reply #2 on: March 24, 2007, 11:32:18 PM »
Two ways you can get that nut out of there, guy the clutch nut socket from Z-1 or use a drift punch to spin it off.
I have only removed a clutch from a 750 and not installed one, I would think that having the appropriate tool would make reinstalling a lot easier.
Good luck
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline crazypj
  • I'm brill, me
« Reply #3 on: March 24, 2007, 11:39:03 PM »
Don't use that thing, they suck.
You are suppost to grip the splines on inner hub (you cant anyway on most Honda's as they have internal pressure plates)
Remove center bearing and leave clutch assembled then use special tool ( if you already took it apart, remove bearing and put everything else back together)
You need the peg spaanner and extension bar, then its easy
PJ
Offline Jonesy
  • Shop Rat
« Reply #4 on: March 25, 2007, 04:50:01 AM »
The tool you pictured is for holding the outer clutch basket. To accomplish that you can simply put the bike in gear and apply the rear brake while undoing the nut. If you haven't used the thing yet see if you can return it.
Here is the tool you need:
« Reply #5 on: March 25, 2007, 05:55:07 AM »
That tool works perfectly well if you have the socket to turn the nut as well! What you have is to clamp onto the spline parts of the inner hub(where the steel plates go) after you have removed all the plates so that you can stop the centre rotating whilst you undo the "special" nut
Offline rab1dwolf
« Reply #6 on: March 25, 2007, 11:13:11 AM »
I have the nut removing tool similar to what jonesy posted.
I dont see where this is supposed to grab anything.  I havent removed the special nut yet and the center plate doesn't really have anything to grip to (#3 in picture below)  I put the bike in gear and lay on the rear brake it still doesn't come free I think its REALLY stuck.  I'lll give my air tools a shot later and see what they can do.
Offline joeb
« Reply #7 on: March 25, 2007, 11:47:51 AM »
Did you straighten out the tab that holds the nut????
Offline Buber
  • A bit of spanner spinner, but definitely not a
  • #820 on old mailing list.... :)
    • Mountain Chalets in Polands
« Reply #8 on: March 25, 2007, 12:31:23 PM »
I have 650, but what i did (frequnetly lately, as i was having trouble with starter clutch - solved now!) was:
Take a socket wrench size 24
dremel it out to form a tool to remove the special nut
block the engine - 2 ways - easy way, put on side stand, step on rear brake, and go!
2nd way - block the transmission either using special tool,  or wooden stick in the wheel, or a coin between the cogs :)
And there you go, you should have the clutch off....
Regards!
Welcome to my mountains!
Mountain Chalets
Offline crazypj
  • I'm brill, me
« Reply #9 on: March 25, 2007, 02:52:31 PM »
I told you the correct and easiest method.
 Remove the bearing ( part #14 I think), leave all the plates and springs in place and undo it through the hole.
If you have an air impact just burp it out
PJ
Offline rab1dwolf
« Reply #10 on: March 25, 2007, 08:47:00 PM »
ok thanks to everyone here, it finally came free.  I pretty much tried everything and the sucker finally broke free.
found out an interestind side note after getting it apart.
the previous owner only had a total of 7 friction plates(the ones with teeth) instead of the usual 8.
still had 7 of the metal clutch plates in there though.  what sort of problems would this have caused?
also one of the metal clutch plates is discolored (brownish/black) should that be replaced? it looks like it had gotten toasty at some point...
Offline mkramer1121
« Reply #11 on: March 25, 2007, 09:41:48 PM »
Don't know about the brownish clutch plate, but as it was burned into my brain today, make sure all the steel plates have the beveled edge facing the same way upon reassembly.  Also, make sure the assembly is properly seated before tightening it back down, as if it is off kilter it can break.
Offline rab1dwolf
« Reply #12 on: March 25, 2007, 10:28:51 PM »
theres a beveled edge? im damned glad you told me that...does it matter which way it faces?
« Last Edit: March 25, 2007, 10:39:44 PM by rab1dwolf »
Offline mkramer1121
« Reply #13 on: March 26, 2007, 04:35:08 AM »
I know the 750 has a beveled edge, as well as the 550.  When we did the 750 yesterday we faced the edge out.
Here's a link to a how to, give the credit to SohcCBs:
http://www.salocal.com/sohc/tech/clutch/cth1.htm
« Last Edit: March 26, 2007, 04:37:21 AM by mkramer1121 »
« Reply #14 on: March 26, 2007, 07:46:32 AM »
Sorry been a long time since i did a 750 and i forgot its backwards! That tool would clamp onto the splines if you turn the centre round, of course that makes it totally useless to you!!!
Offline rab1dwolf
« Reply #15 on: March 27, 2007, 01:13:51 AM »
cool thanks a ton to everyone.  Ill be reassmebling it all later this week, hopefully it turns out as easy as it all looks!
