Author Topic: Fork help please  (Read 2105 times)
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
Fork help please
« on: March 26, 2007, 12:40:29 PM »
Now for the problem of the day.  I've got the fork seals out using a special tool, not easy but doable.  The problem I have with both sides of my forks now is the bottom hex bolt on each spins freely.  I can't get either one out and I can't tighten them again either.  I'm thinking I shouldn't have touched them...
I assume the top tube won't come out without removing the bottom hex bolt?
Thanks.
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
kettlesd
Re: Fork help please
« Reply #1 on: March 26, 2007, 12:43:04 PM »
Standard trick is to insert a length of broom handle down the tube to hold the damper rod in place, then you can turn the bolt.
Offline Sweep
« Reply #2 on: March 26, 2007, 12:48:55 PM »
Thanks, I was hoping for a trick!
« Reply #3 on: March 26, 2007, 12:54:25 PM »
An air impact tool also allows inertia to both free and tighten those allen bolts.  Carefull with the tool's torque setting upon tightening.
Offline Sweep
« Reply #4 on: March 26, 2007, 01:03:39 PM »
The broom trick worked.  I do have to start using my impact tools more.
Offline Sweep
« Reply #5 on: March 26, 2007, 03:05:16 PM »
Good deal!  Make sure you have the tubes in the lower fork legs when you install the new seals, just slide em down then use a peice of PVC pipe to slide hammer them into place.  That will ensure they seat evenly in the groove.  Mabey you already know all of that, but it sounds like you havent done it before...so.
All new and good info for me, thanks.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #6 on: March 26, 2007, 06:40:58 PM »
Irony:  Sweep had to use a broom handle to fix the honda.. :P :P :-\
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline Sweep
« Reply #7 on: March 27, 2007, 07:28:48 AM »
Haha!  I need to change my name to AirImpact
