Author Topic: small fairing  (Read 1212 times)
Offline donny
small fairing
« on: March 30, 2007, 08:37:17 AM »
 ;DHow high must the windshield be to keep the sensation of my glasses blowing into the asphalt at 60 mph? I don't know anyone with a windshield on their ride, except barn doors.  Proper height is supposed to be eye high, but how much lower can you go?   Preferably some kinda mini fairing with the smaller windshield. I usualy wear a helmet, but not always.  thanks,  Donny
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Re: small fairing
« Reply #1 on: March 30, 2007, 08:59:40 AM »
Maybe something like this would suit your needs....
http://www.sohc4.us/forums/index.php?topic=19938.0
cheers
Andy
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: small fairing
« Reply #2 on: March 30, 2007, 09:02:52 AM »
Depends on how much you crouch over the tank.
No.
Offline merc2dogs
Re: small fairing
« Reply #3 on: March 30, 2007, 10:15:23 AM »
  On my 750 with low drag bars, if I clip a 4 inch wide strip of aluminum on the speedo and tach it's enough to stop the wind buffeting my helmet.
 Doesn't need to be all that tall. Similar to the way a bug deflector works on a car, just enough to get the air moving upwards.
 The aluminum I use is a strip about 11 inches long, 4 inches wide with the ends curved slightly to wrap around the gauges, used a pair of large hose clamps to hook it on. Makes a noticeable difference when riding and is easy to remove, and stores under the seat, great when a short ride turns into a long run, and it starts getting cold.
  The air hits me just about mid forehead, found out by accident, had to carry some crap home and over the instruments was the only place to put some of it, noticed the huge change in airflow, and experimented.
 Seeing that  the 4" strip deflects the air to my forhead, I'd say you'd have to adjust for your height
  Also, it's painted black on mine.
  Do like I did and experiment with thin plywood to get the best width
Ken
