Author Topic: CB650 Valve Seals  (Read 946 times)
mrclyde50
CB650 Valve Seals
« on: March 30, 2007, 08:13:04 pm »
I'm going to replace the valve seals (and a few others while I'm at it). I know that I can remove the head to do it but I was told that I can shoot some air into the cylinder (head still on) and somehow get to the seal to remove/replace. I've got a good manual but I'm not seeing how that's possible.
Is it??
Offline rhinoracer
Re: CB650 Valve Seals
« Reply #1 on: March 30, 2007, 08:37:45 pm »
I've read about it but never done it myself. I'm guessing it would be a bit tricky but taking your time it could be done. Maybe you don't even need air, not sure how far down the valves drop with the piston at TDC.
Maybe you could fit some needle nosed vise grips through the intake and exhaust ports to hold the stem while inserting the locks. You just have to be careful not to damage the stems.
Baja native.
