Author Topic: Valve Cover Removal  (Read 1098 times)
Offline Bido
Valve Cover Removal
« on: March 31, 2007, 06:27:30 AM »
I am in the process of getting my 78 750 SS for spring and am replacing all the screws with stainless allen head my question is can I remove the valve cover with the motor in the frame the gasket does not leak now will I have to replace it if I remove the cover I think it would be a lot easier to adjust the valves with the cover off. Any input would be a big help.
Thanks in advance
Bido
1978 CB750 Supersport F3
1981 CB750 K
jsaab2748
Re: Valve Cover Removal
« Reply #1 on: March 31, 2007, 06:30:22 AM »
Engine will have to come off to remove the cover, but you could just replace the screws one at a time and probably be ok with the same gasket.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: March 31, 2007, 09:01:40 AM »
Bido,
Get yourself a set or three of these:
http://www.motionpro.com/motorcycle/tools/tappet_feeler_gauges/
and you will prolly change your mind about the easiest way to adjust tappets.
When I first got my 550, I too was concerned that feeler gauges, even the ones with the 45-degree bend, simply wouldn't fit into the hole under a tappet cover.  I was further confused when I started to read this forum.  People refereed to tappet adjustment as simple.
Then someone turned me on to the right tool!
Guess it's taking me a bit to Learn the differences between automotive and motorcycle repair.  The concepts are the same, but the tools and techniques can differ greatly!
« Last Edit: March 31, 2007, 09:05:46 AM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Bido
« Reply #3 on: March 31, 2007, 12:11:51 PM »
Thanks for the tip I am sure this is the ticket.
Bido
1981 CB750 K
