Author Topic: Cheap and effective fuse box/fuse holder replacement.  (Read 3438 times)
liaudio
« on: March 31, 2007, 11:39:17 PM »
This is posted in the tips/tricks section as well.
Are you having fuse blowing problems because your fuse holder is old and dingy?
We all know how notoriously lousy the stock Fuse holder / fuse box is.  If they are old, the connections get really corroded, can melt the plastic, and even have a possiblitiy of an electrical fire.
In my experience, I have ditched the stock fuse holders all together.  I never liked those cylindrical fuses either.
What works amazingly well is to just cut the wires and crimp on female spade connectors to the feed and draw side.  Then take an appropriate 12v blade type automotive fuse and put that in-line.  Viola!  Cost? About $2!
It not only eliminates the fuse-box, but you can eliminate the connector clip that connects the fuse box to the main wire harness as well. My theory is: eliminating electrical connectors = less resistance = higher voltage.
I relocated all my eletronics under the seat, so these pictures will look a little different than stock configured bikes.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
Re: Cheap and effective fuse box/fuse holder replacement.
« Reply #1 on: April 01, 2007, 01:33:37 AM »
Wow. . .kewl idea. I was trying to fit those individual fuse holders in there and having trouble with it. Those look like they take up a lot less space - flatter. Those kind of fuses are way easier to find, too.
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline Rsnip988
« Reply #2 on: June 23, 2007, 12:42:37 AM »
thank you for this genius idea, i did it myself, saved a lot of time money anbd space
THANK YOU
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline cben750f0
« Reply #3 on: June 23, 2007, 02:00:30 AM »
thats cool, i did this, though it was $12 aud... makes a huge difference though!!!!... thanks for the heads up...
http://www.sohc4.us/forums/index.php?topic=313.0
peace
luvhonda750
« Reply #4 on: June 27, 2007, 04:06:53 PM »
Thanks, this is a very nice fix, I was going to spend 20.00 on ebay for another one that may have been broken.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #5 on: June 27, 2007, 07:06:22 PM »
Hey all  a few years back I did this I bought some circut breakers and took an old worn out stock fuse box and wired in the  breakers all you have to do is  cut out the box leaving the six wires at three differant lengths  put some crimped eyelets on to the wires and bolt the  breakers on with  the little nuts that come with them  tape them up and bingo no more blowing fuses just use the right amps I had an  issue with my brake light  (I put one up on the back of sissy bar) well comeing to a stop all of a sudden bike would die  I would look down and my dash lights would be on she would fire back up and off I would go finnaly after picking up a pair of boots at the cobblers and stapping them on the  rack I saw the bare wire culprit  at the time I only had two circut breakers so one of them was doubled up but that setup worked for years  and as Im typeing waiting for delivery of some new 10 amp breakers  hope this helps have fun Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline mark
« Reply #6 on: July 20, 2007, 09:33:38 PM »
I liked the ideas above - using blade fuses and eliminating the extra connection to the main harness.
I liked moving the fuses to under the seat even better - saves tugging on that delicate side cover!
The harness connector was in pretty good shape, however - and I didn't want to cut up the harness.
I removed the female terminals from the plastic harness connector, cleaned them with a small wire brush, gave a gentle squeeze with the toolkit pliers, and applied some bits of heat shrink tubing. Plugged in the fuses and covered the mess with a rubber relay cover from some car at the junkyard. My spare fuses sit atop the airbox with the toolkit.
Happy trails.
« Last Edit: August 06, 2007, 08:42:42 PM by madmark73 »
F you mark...... F you.
Offline riktaboy
« Reply #7 on: July 21, 2007, 04:15:51 PM »
It's amaazing how such a simple thing that should be so obvious to do, slips right by you.  What a great idea, thanks for sharing it.
Offline neil young
  • striving to be an
« Reply #8 on: August 06, 2007, 10:22:03 PM »
Happy trails.
[/quoteother than shrink wrap and some fuses was then anything else you had to purchase for this project....which buy the way is a great idea
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline mark
« Reply #9 on: August 06, 2007, 10:54:57 PM »
That was it. About 9" of shrink tube and some fuses - stuff I had lying around anyway. I think the cute rubber bootie was a Toyota part - Nissan maybe? That was a freebie from the boneyard.
My fuse box was melted to crap. I left it in there just for looks - in case I pull the cover for some OTHER reason! ;D
It'd sure be nice if I could fix the carbs that cheap. ;)
Happy trails.
BTW.. At the yard, I was looking at some 8 pole connector plastics that the Honda terminals would snap into.. (with the wires paired side by side to make a 'fuse block' ) All needed a bit of plastic removed between the terminals to plug a fuse in fully. I may try that in the future.
