On speculation that #3 isn't getting fuel, try this:
Kill switch in off (no ignition)
Fuel petcock on
Choke full on
Throttle at idle
Get 10-20 revolutions of the crankshaft.
Each spark plug you remove should be wet with gas. If #3 is dry, you have a carb problem, Idle circuit.
You can repeat the test with throttle wide open to test main jet flow.
