Author Topic: Silver braze caliper piston?  (Read 7710 times)
« on: April 02, 2007, 01:04:25 AM »
Seeking opinions:
I have some caliper pistons with pits deep enough to interfere with retraction.  I get squeaking brakes and poor retraction on the worst ones.  Anyway, I'm thinking of filling the pits with silver braze and smoothing them over to restore the original contour.
Is there anything about dissimilar metals, galvanic action, brake fluid reaction, or corrosion I should know about beforehand?
Will the heat from silver brazing destroy the chrome plating on the remainder of the piston?  Does chrome melt at a lower temp than silver?
What about brass or bronze?
Surely silver solder melts at a lower temp than chrome.  Is this too soft for the repair area?
Am I just being too cheap about saving old parts?  It bugs me cause most of the piston is good, apart from the bit that interfaces with the seal. ::)  I know a new piston will just corrode, too.  And, I've got 5 calipers in need, now.
Is this a job for the micro acetylene torch?
Constructive comments welcome. ;D
Offline Kevin400F
Re: Silver braze caliper piston?
« Reply #1 on: April 02, 2007, 03:02:28 AM »
Lloyd, would you be interested in trying one of my phenolic replacement pistons?
Look here for a description:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AMESE%3AIT&viewitem=&item=320099300063&rd=1,1
Best regards,
Kevin
Offline Steve F
« Reply #2 on: April 02, 2007, 04:42:47 AM »
Seeking opinions:
The problem with silver braze (silver solder) is that you have to get t he temp up to around 1100F for the metal to start to flow which would peel the chrome off.  You can't just spot braze something like that because of the mass you need to pre-heat.  See if there's a machinist in the area that can spin off a couple of pistons in stainless for you, or go with the phenolic versions.
« Reply #3 on: April 02, 2007, 05:39:47 AM »
I have done some measuring in the past i it  is my opinion that 1 1/2 inch stainless bar is exactly the right diameter without machining except for "hollowing" out. might be worth talking to a local machinist
« Reply #4 on: April 02, 2007, 06:28:58 AM »
If you want fiddle with it knowing full well you may need a new parts, you may try common solder or a electronics silver solder. The melting point is fairly low and it has a non corrosive flux. It can be buffed smooth. I am not sure an iron will heat the work enough to get it to flow but it is worth a shot.
Offline starion88esir
« Reply #5 on: April 02, 2007, 07:54:31 AM »
Best regards,
Kevin
Will these fit a 76 750F or do you have ones that will?
71 CB175 - next project
76 CB750F - current project
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #6 on: April 02, 2007, 07:58:07 AM »
There would be no way to get the entire piston hot enough with a soldering iron, not even a soldering gun.  Have you thougt of trying epoxy?  You might be able to find and epoxy that is silver colored.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline wardmoto
« Reply #7 on: April 02, 2007, 09:55:07 AM »
My holes were not too bad, but I used JB Weld with no problems.  That, a new seal and the piston bore dressed, and I was able to do away with Honda's goofy bolt spring arraingmernt...I have complete retraction and no drag :)
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
« Reply #8 on: April 02, 2007, 10:33:37 AM »
TT,
I have several saved used pistons just waiting for a rebuild breakthrough! Yesterday I assembled the two calipers on my 550, had the new OEM pistons here for a couple years. Man those pistons are heavy. I've been watching those phenolic pistons Kevin and haven't heard anything negative, so TT....... go for it, put those damaged pistons on the scrap heap and try phenolic!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: April 02, 2007, 12:17:57 PM »
This isn't an area in which I would experiment. I'd just replace them.
The old ones make nice paper weights. If you now have several, hang on to them until Christmas, use them for stocking stuffers. ;D
« Last Edit: April 02, 2007, 12:50:58 PM by Bob Wessner »
Offline jreich
« Reply #10 on: April 02, 2007, 12:31:39 PM »
But it is so fun to experiment!
Try some 95% tin solder with an acid flux core...melts at around 450 degrees, and seems to be pretty strong
If it doesn't set-up correctly, you should know before you get on the road.....and if not, you've always got that rear drum!
Offline Cowboy
« Reply #11 on: April 02, 2007, 12:33:20 PM »
TT,
I doubt you would need an oxy-acetylene torch to get the piston hot enough to melt silver solder. I suspect that  mini-torch would tend to heat the part unevenly anyway, given the small flame. I would try a straight acetylene torch, like a pestolite, or even just a propane bottle with one of those cheap torches on the end, like people use to sweat-solder copper pipes.  The trick is to use a large flame, keep it moving around the piston, and heat up the part evenly over it's entire surface, until your solder flows. That would be difficult with a mini-torch.
You can get silver solder in a range of alloys that melt at different temperatures. I'm a silversmith, so I keep a range of solders handy from brass (which melts at a pretty low temp, to silver solder in "easy", "soft", "medium, ", or "hard" which melt at progressively higher temps.  I can't offer any advice on their adhesion to a brake piston, but it may be worth trying.
I won't offer my opinion on the safety aspect, since you didn't ask. (It's my pet peave about internet forums that people continually offer their opinions about how THEY would just throw money at the problem, or how THEY wouldn't take that risk, etc., and rarely adress the question you actually asked.)
1964 Honda CT200
1967 Chang Jiang 750 Sidecar
1970 Honda CB350
1978 Honda CB550
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: April 02, 2007, 01:19:06 PM »
I believe if you reread his post, he left room for comments beyond the purely technical aspects of what he is contemplating. Hopefully, members would always be willing to post a thought about actions they felt would put another member at risk.
« Reply #13 on: April 02, 2007, 02:31:18 PM »
I thank you all for your responses so far
Kevin,
I'm very much interested in the phenolic pistons.  However, I need more than one.  And, I don't want to go through an auction cycle and pay excess shipping for each piston.  I still may do that.  But, probably not until I destroy the ones I have through experimentation.
I've heard reports of the phenolic swelling over time with contact from brake fluid.  Have you any data on this?
Steve F,
According to my metal melting chart, Chrome melts at 3034F, the steel melts at 2500F, copper 1980F (if they preplated with that) and my silver braze alloy 45 flows at 1300 F.  Oxy acetylene temps are 5000F.  Are you saying it is not possible to control the temps in order to prevent plating destruction?  Or, is it just very difficult?  Perhaps silver solder's 680 to 771 F temps are a better choice, with a lower temp heat source?
BryanJ
I can't find any local machinists that will do single piece work without paying for production set up time.  They only become interested when there is a minimum of $500 transferred, then they will talk details of the job.  I have a lathe so I may look into the SS bar.  I have no experience with cutting SS, however.  And, I thought the roundness tolerance was critical for this application. Then there are the cutting bits to buy...$$$  Phenolic looks to be a more attractive option, at this point, if I fail to repair what I have.
BobbyR,
Ordinary electronic solder I have lot's of experience with using.  I fear it is simply too soft for this application.  You can gouge it with a thumbnail.  Imagine what crystallized brake fluid could do.  Even frequent fluid changes won't replace the fluid right next to that seal.  Further, I think the mass of the heating iron would need to be as big or bigger than the brake piston, in order to gain enough heat to wet the pitted crevice.  I may still try this, if other methods prove to be too destructive. ;D
kslrr,
Yes thought of epoxy.  JB weld (with its duct tape like utility) is a distinct possibility.  I have yet to learn of its tolerance to brake fluid.  A bit concerned about its heat tolerance.  And all resins seem to deteriorate with age in an unpredictable manner.  Not to worried about the metal contact.  But, the solvents and plasticizers in the seal material may soften the resin binder with constant contact.  Still, I have several pistons to experiment on.
wardmoto,
Ah, a test subject!! How long since you used the JB weld patch?  And, without "Honda's goofy bolt spring arraingmernt" , how do you keep the brake pads from contacting the disc in leanover turns and road bump shock distortions? ???
bwaller,
But, my pistons are over 90% smooth and good!  It's just that one, somewhat significant area that has a problem. ::)  Do you throw a person away because he has bad knees?  Even with crutches he'd be good for something. ;)
That's a generous offer, Bob, that solves a lot of issues.  When can I expect delivery?  I'll be happy to return the stocking stuffers!! Sorry to hear you've run out of coal. ;D
jreich and Cowboy,
I will likely try the high temp solder approach, if I find silver braze too difficult or destructive to the piston host.
As to safety:
 If the pits don't leak with the current seal, filling them will hardly make thing worse.  As long as the brake fluid pressure is transferred to the brake pads and rotor, the dang thing is gonna stop the bike.  It's physics, not magic.  It is very hard to imagine that any kind of failed patch would actually stop the piston movement in the caliper bore.  If the brakes drag before and after the patchwork, it will still stop the bike.  If you understand the physics required to make the caliper work, there seems little risk of actual danger.  Inefficiency, okay.  But, danger?  If someone can tell me of a specific issue besides the "sky may fall", I'll certainly listen to any facts I've overlooked.
I always two hand squeeze the brake lever with all I've got before road testing my brakes.  If nothing pops or leaks during or after that test, I don't think it's going to let go with a one hand squeeze, even with an adrenaline surge.
Thanks ALL for your comments!  Keep 'em coming!
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #14 on: April 02, 2007, 04:40:59 PM »
I just took a look at my old piston, similarily corroded at the seal interface.  These obviously have an inside and an outside surface that are different one from another.  The inside (fluid) side is the chromed surface.  The outside (pad) side appears to have some sort of metal 'filler' filling the chrome 'cup' to an almost flush level.  Without putting any consideration at all into the force being exerted on this 'filler' stuff, what about just flipping the piston around and putting it in backwards?  Maybe seal the top with your silver braze, the tolerances would not be a real issue there.  And then the seal would run against the remaining smooth portion of the piston. That said, I have one of Kevin's phenolic pistons just waiting for the full brake replacement I'm going to do this winter.  Oops, it's spring already (...and my brake has stopped giving me any problems ever since I got the new piston).
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Kevin400F
« Reply #15 on: April 02, 2007, 06:10:43 PM »
Lloyd, the pistons are extremely stable dimensionally.  Bear in mind, these are based on OEM-spec automotive brake pistons......all I do is alter the overall length to be compatible with the Honda caliper.
I'll be happy to work out a quantity purchase with appropriate pricing and shipping cost.  Only one possible glitch......beyond the piston I currently have on eBay, I only have four left.  I need to contact the manufacturer and place an order for additional stock before I can commit.
If you want to discuss further, you can e-mail me at kthunter01@sbcglobal.net
« Reply #16 on: April 02, 2007, 06:50:21 PM »
OK, here is what I did since my piston fired itself into the woods behind my house as I heated it. I gave the caliper to my friend who distributes import auto parts. His re builder gave me what amounts to a racing caliper with a SS piston and proper seals. It cost me $60 total. I am as cheap a DIY SOB as you will find, but $60 was even ok for me. But  TT go for it, I am with you in spirit. I think the lead free solders today are much harder than the good old lead we inhaled in our youth.
Offline wardmoto
« Reply #17 on: April 02, 2007, 07:42:05 PM »
TT, here is the rub... Most of my experience is with multi piston calipered sport bikes.  I know from this forum, that my piston wasn't in horrible shape compared to others I saw (I of course neglected to take pictures of it)...perhaps I would have been OK with a new seal and no JB...if that was the case, and my fix has already deteriorated (if it is going to) I might not ever see a problem.  The brake has had fluid in it for 3 months.  As far as rub or drag, they all do to a certain point and I am sure you knew that...I think I know what you are getting at.  In my haste to respond to you while at work in a timely manner, I neglected to tell you that I chose to abort all hope of using the original MC and simply ebayed a fantastic CBR F3 MC for 45$...perhaps that helps a bit to prevent the awful drag the stock set up gives (I have a bone stock 350F...its brakes are problematic).  I know on my SV 1000, when I am on the gas through bumpy undulations and the front end is wiggling all over the place ( and I am giving thanks for the damper!)...when it is time to slow the pace, I need to pump the binders up a bit as the oscillations caused them to retract away from the disk a bit more than usual. I have never had any problems like that on my cafe (obviously I am not power wheeling over bumpy roads at 75 mph either, not with 30ish hp!)).  Regardless of what I do, bumps, abuse etc... ( I practice repeated panic stops often) the brake acts predictably and doesn't drag or squeal.  Hope this helps, sorry for omitting a few details earlier.  Good luck and thanks for all your awesome input...my 350F was my first cafe and everyone here helped tremendously.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
Offline mrbreeze
  • Not your average
« Reply #18 on: April 02, 2007, 08:05:43 PM »
$60 is cheaper than what the stealership will charge you for a piston alone (that will eventualy go south again anyway). What about the dot 5 conversion I have heard about here? No more internal corrosion??
MEMBER # 257
« Reply #19 on: April 02, 2007, 09:20:38 PM »
I'm afraid that simply isn't true.  While Dot 5 doesn't attract water and hold in suspension like Dot 3 or 4, any water that does enter the system simply finds the low point in the system and collects there to corrode the inards.
At least with the glycol based fluid, changing the fluid also removes absorbed water.  You pretty much have to dismantle the hydraulic vessel to address internal corrosion with DOT 5 systems, even if you have a routine fluid change schedule.
Offline mrbreeze
  • Not your average
« Reply #20 on: April 02, 2007, 09:45:04 PM »
If dot 5 doesn't attract H2O.......how will it enter the system (unless some smart ass pours it into the master??????
MEMBER # 257
« Reply #21 on: April 02, 2007, 10:04:32 PM »
Seeking opinions:
This has to be a first on this forum...LLoyd asking our help. ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline mrbreeze
  • Not your average
« Reply #22 on: April 02, 2007, 10:20:45 PM »
Seeking opinions:
Sam. ;)
Ya know Sam........I was thinking the same exact thing!!!!! Don't recall Lloyd ever asking for advice but rather offering it.......I'm kinda afraid to offer my 2 cents on the subject!!!!
MEMBER # 257
« Reply #23 on: April 02, 2007, 10:29:03 PM »
 ;D ;D ;D ;D ;D
Sam ::)
« Reply #24 on: April 03, 2007, 12:05:01 AM »
Each time you open the system to check the level, humidity from the air enters.  On the next cool down cycle is condenses on the inside surfaces.
I also read that water can come in past and actually though the rubber seals. Poly based plastics are water permeable. Is your master reservoir plastic? Is your SS brake line core plastic?
Here is an excerpt from :
http://www.babcox.com/editorial/bf/bf40142.htm
"Moisture also creeps into the system to further add to the contamination problem. Humidity in the air can be drawn into the fluid anytime the fluid reservoir is opened for inspection or anytime a brake hose, line or bleeder valve is opened when servicing the brakes. Even if the fluid reservoir is never opened, moisture will still infiltrate the system through microscopic pores in rubber brake hose. The rate at which this happens depends on the age of the vehicle and the type of brake hose used. Newer hose made with linings that are less permeable to moisture help extend the life of the fluid. Even so, moisture can still slip past piston seals in wheel cylinders and calipers.
DOT 5 also cannot disperse moisture that enters the system throughout the fluid like DOT 3 and DOT 4 fluids. Any water that does get inside tends to "slug" and settle to the lowest point in the system, which is usually the calipers and wheel cylinders. Slugs of pure water are not something you want inside a brake system because they concentrate corrosion and increase the risk of pedal fade if the water gets hot enough to boil (it only takes 212 F to turn liquid water into steam.)"
Obviously, the probelm is more severe in wet, humid areas than it is in dry, arid areas.  But, it is one reason why the Military is looking for way to convert their fleet back to a glycol based fluid.  Dot 5.1 has all the temperature extreme benefits of DOT 5 without the maintenance issues dot 5 brings.  It is much cheaper to simply replace fluid on a regular basis, than to dismantle the system to address corrosion issues.
