Author Topic: Fork Seal Removal  (Read 10184 times)
snoop
Fork Seal Removal
« on: April 03, 2007, 09:10:41 AM »
I had a lot of trouble getting my fork seals out.  I was digging in to the edge of my fork with screw drivers so I went out bought a seal remover at pepboys and still had a lot of trouble. It was not budging.  I sprayed some “pb blaster” around the edges of the seal and literally with in seconds of using it I used the seal removal it popped out with little effort.
knowseeker
Re: Fork Seal Removal
« Reply #1 on: April 03, 2007, 02:22:30 PM »
Thanks for that tip, I have a fork seal replacement on a goldwing coming up and will give that a whirl!
Dave
Williamston, MI
1974 CB350F
1978 GL1000
Offline xtalon
« Reply #2 on: April 03, 2007, 04:15:19 PM »
Are you sure it wasn't PB Ribbon?   ;D
Thanks for the tip.  I'll be doing this over the next few weeks myself.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
snoop
« Reply #3 on: April 04, 2007, 07:52:22 AM »
I am pretty sure it is PB Blast, but from that resource that tt just posted, wd40 should work the same.
Offline xtalon
« Reply #4 on: April 04, 2007, 08:50:29 AM »
PB Ribbon = Pabst Blue Ribbon
PB Ribbon helps too because it helps keep cursing to a minimum when working on these bikes.   ;)
Sorry, I hope I didn't confuse anyone.  I was just being my usual smart-arse self.
I did have to do a search for PB Blast because I had never heard of it.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline dagersh
    • Photos
« Reply #5 on: April 04, 2007, 11:16:15 AM »
So, I guess it would be prudent to use both PB Blaster AND PB Ribbon.  Just be very careful if two-fisting! ;D ;D ;D
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline hymodyne
« Reply #6 on: April 12, 2007, 04:00:04 PM »
mine came out after I applied a propane torch to the area and then pried them out with a thin bladed screwdriver.
hym
Offline BeSeeingYou
« Reply #7 on: October 21, 2009, 11:23:06 AM »
Bought this tool at Harbor Freight for $4.00 for pulling the fork seals on my 75 XS650.  Worked great and no danger of scarring or distorting your fork from prying with a screwdriver.  Mine were really stuck in there and it took at least 10 hammer blows to get them out.  No way would they have come out without damage prying them out with a screwdriver.
« Last Edit: October 30, 2009, 11:28:43 PM by srust58 »
Offline DaytonGuy
« Reply #8 on: October 30, 2009, 06:22:46 PM »
I went to the local odd lots and got a cheap set of c-clamps.  They usually sell them is sets of three with the smallest being 2-3 inches.  They cost like $5.00 or so.  The small one fits inside the fork.  Use a piece of wood on the lip of the fork and place the clamp on the underside of the seal....tighten clamp.  Work your way around like that and it will pull right out....all for about $5.00.  PB Blaster helps too...if you have it.
Offline m00ntan
« Reply #9 on: November 03, 2009, 06:57:31 PM »
Thank you.  Mine came out with Aerokroil and a propane torch.  I actually heard them POP.
CB750K4
CB550K1
CM400C
Offline paulh1282
« Reply #10 on: July 01, 2011, 02:25:25 AM »
ok so I must be the odd ball, when I drink pbr the cursing usually gets worse... ;D
Offline sandman
« Reply #11 on: May 05, 2013, 08:43:03 PM »
Another minor tip: no matter what you use to pry the seal out, don't try to pry it out with two pulls. Work your way around the circumference bit by bit- this prevents you from tipping the seal in the fork counterbore and wedging it in. Some seals have metal outer bands, and it is possible to really get them stuck being impatient.
'72 CB500 my first four
'89 RC30
'01 CBR1100XX
Offline Redline it
  • thread killer
« Reply #12 on: February 21, 2021, 01:52:48 PM »
back in the day, my dad, a pretty sharp oakie with a mechanical common sense that was always just over built for whatever was gonna be needed to make it work, none of his projects crapped out before he did. aircraft mechanic sergeant usmc at about 18.   but he made a steel 3/8 or 5/16 rod, it had a slight bend on the seal side of it and the round was cut in half and tapered back inch or so. and you insert it though the damper bolt hole and then position the slight bent side just under the seal. holding it upright looking into the seal to make sure it wasn't gonna mis and nick the seal seat, and the rod is just outside of the bottom, and tap the whole thing on the bench, tailgate or whatever. pops it right out. pretty easy to store, only i can't find where i put last. think i'm gonna try the boiling water and wd-40.
