Author Topic: Penetrating oil test  (Read 38446 times)
« on: April 03, 2007, 11:15:34 AM »
I got the April/May edition of Machinist's Workshop magazine yesterday.
Another very talented Lloyd did an interesting test of penetrating oils where he measured the force required to loosen rusty test devices.  Get the issue if you want to see how he did the test.  But, I thought the results he reported interesting.  Maybe you will, too?
Pentrating oil  /  Average load     /  Price perfluid ounce
None             / 516 pounds       /
WD-40           /  238  pounds     / $0.25
PB Blaster       /  214  pounds     /  $0.35
Liquid Wrench  /  127  pounds    /  $0.21
Kano Kroil       /  106  pounds     /  $0.75
ATF-Acetone mix  /  53  pounds  / $0.10
The ATF-Acetone mix was mixed 1 to 1 ratio.
Offline burmashave
  • Forum Immoderator
    • burmashave.net
Re: Penetrating oil test
« Reply #1 on: April 03, 2007, 12:11:04 PM »
Wow.  Thanks TT.  I had always wondered how Liquid Wrench compares to WD40, and it's good to know there's a cheap big gun for extremely rusted fasteners.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline Jonesy
  • Shop Rat
« Reply #2 on: April 03, 2007, 12:16:37 PM »
In the antique outboarding circles, ATF has been the favorite for releasing gears rusted to shafts, etc. since ATF has lots of dispersants, etc. in it. So, I'm not surprised.
Offline greenjeans
  • 1972 CB750K2
« Reply #3 on: April 03, 2007, 01:57:16 PM »
What the heck is ATF made of?
Offline Geeto67
  • A grumpy
« Reply #4 on: April 03, 2007, 02:32:20 PM »
can I just use straight ATF? isn;t ATF by itself hydrosopic?
Maintenance Matters Most
« Reply #5 on: April 03, 2007, 04:29:44 PM »
You can use any kind of Automatic Transmission Fluid you want, I suppose.  The acetone thins the fluid viscosity for penetration into tiny crevices, I expect.
What is the relevance of hydrosopic?  (A word I can't find in the dictionary, btw. Did you mean hygroscopic?  ???)
gold01ca
« Reply #6 on: April 03, 2007, 08:30:25 PM »
great info TT, thank you!
gonna try the atf/acetone on my rusty front disc bleed screw (new speedbleeder going in)
Offline ChevelleSSLS6
  • Member #4051
    • my myspace, yay.
« Reply #7 on: April 03, 2007, 10:07:07 PM »
the atf/acetone would be great in the compressed air cans... they used them at the dealership (dodge) I used to work at as a shop kid (I used the b-word there but gotta play nice here ;))  First you put the chemical you want to spray (there they used mostly brake clean, here I'd use atf+acetone) and then pressurize it with compressed air.  And it's reuseable.  Dunno where I could pick one up.
"What about incomplete idiots?" -TwoTired
"What's a leakdown test?  I filled the cylinder that looks like this with some water and let it sit overnight. The water didn't go down any.  I thought that would tell me about the rings." -Dead Guy of AMCforums
1977 CB550f- sold
2007 Kawi EX650- curre
Offline rhinoracer
« Reply #8 on: April 03, 2007, 10:10:46 PM »
Valuable info, thanks. Wish I knew before breaking my sticking piston rings. :o
Baja native.
Offline jonbuoy
    • My rebuild:
« Reply #9 on: April 04, 2007, 01:50:38 AM »
ATF and acetone  :o you'd want to be carefull where you sprayed that.. - thanks for the tip.
Offline Wheelhorse77
  • She's got some Juice
« Reply #10 on: April 04, 2007, 04:54:25 AM »
I use this stuff from State Chemical called State Pen.
Blew PB and Kryoil out of the water.
It would have been interesting to see how well it went against the ATF Acetone.
77 750F2 ressurected from the dead
ASE Advanced Level Master Tech
boober
« Reply #11 on: April 04, 2007, 03:12:17 PM »
You can get the compressed air cans at Harbor Freight Tools, they have a website, harborfreight.com.  I see them on sale all the time in my local store for about 5 or 6 bucks
Offline gregk
« Reply #12 on: April 05, 2007, 07:55:21 AM »
I showed the results of this test to the auto machinist next door and he was suprised that COKE wasn't mentioned in the test.  He claims that he has had good results with it.
I don't want it to go like a motorcycle, I want it to go like a rocket!
Offline hopterfixer
    • My flickr Gallery->
« Reply #13 on: April 05, 2007, 08:04:30 AM »
Those Compressed air cans can be found at Grainger.  I have three I use at work.
http://www.grainger.com/Grainger/wwg/itemDetailsRender.shtml?ItemId=1611573362
gold01ca
« Reply #14 on: April 05, 2007, 08:50:03 AM »
perfect hopter!
thanks for that link.
Offline puppytrax
« Reply #15 on: April 05, 2007, 07:08:44 PM »
This may be dumb...but where do you find acetone?? Is there a popular brand name for it??   ???
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #16 on: April 05, 2007, 07:16:44 PM »
any hardware store or auto supply should carry it with other thinners.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
gold01ca
« Reply #17 on: April 05, 2007, 07:20:31 PM »
paint store (ex. Benjamin Moore etc) for sure if you cant find it at your auto supply place.
in the paint area of Home Depot, Lowes etc.
and it is labelled ACETONE.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #18 on: April 05, 2007, 07:51:41 PM »
If you need just a little bit, its also called (regular) nail polish remover. .  . . .lol    ;D
('regular' because there is also non-acetone kind)
Look for the super cheap brand because the fancier brands will have 'protein fortifiers', floral scents, etc. The super cheap stuff is literally just acetone.
« Last Edit: April 05, 2007, 07:53:17 PM by MoTo-BunnY »
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline GammaFlat
« Reply #19 on: April 05, 2007, 08:51:51 PM »
For the sake of completeness, here is the link to the Harbor Freight re-usable aerosol spray can: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1102  ($9.99 but as alluded to above, HarborFreight frequently has sales and I'm told by HF employees that everything goes on sale there at one time or another)   I'm going to get one right away and I'll fill it with the "acetranny fluid".
K6
85 Goldwing
Offline coolcat2002
« Reply #20 on: April 05, 2007, 09:22:30 PM »
I was going to buy Nail Polish Remover for $0.99 but then I looked at my Brake Cleaner and the main stuff is acetone.  It even smells like a nail polish remover.  I got a $1.99 aerosol can by ValueCraft at Autozone.  (needed to clean my brakes also)  The name brand stuff don't explicitly say what's in it but this one did.
Acetone is otherwise $13.50/ gallon at my Home Depot.
When I took organic chemistry, they use plastic squeeze bottle with an angled sprout to store dilluted acetone & clean stuff, $1 maybe.
That link to the $38 pressure can, man, yall rich or something?
Seriously, like $10 for a single rubber carb boot??  When I read things like that it just discourages me to own a CB.  I couldn't give a rat's ass about OEM sandcast BS.  They should put that on the Rich Guy's Forum.  I mean if you're gonna blow that kinda money on a piece of rubber, why bother coming to this forum.  On a positive note, thanks for putting up a cheap alternative and other homemade stuff.
This and Slickdeals.net are my favorite forums.
« Last Edit: April 05, 2007, 09:28:39 PM by coolcat2002 »
Offline MoTo-BunnY
« Reply #21 on: April 05, 2007, 10:26:58 PM »
he he. . .now I can be the total tuff motorcycle chick and do my nails with Brake Cleaner (and then color using Honda touch up paint - I like that fiery orange color)  ;)
1973 Honda CB500K2
Offline hopterfixer
« Reply #22 on: April 06, 2007, 06:10:42 AM »
I posted the link, not even having looked at the price, I have three at work that do the job well and was sharing.  I have some of those plastic squeeze bottles I keep my acetone in, they would work perfect for the job too since they have a very fine angled tip.  Has anyone here used Mouse Milk?  I wonder how that fits in the penetrant chart TT listed??
Offline dusterdude
« Reply #23 on: April 06, 2007, 06:21:09 AM »
liquid wrench better than pb?,thanks tt,you just blew my bubble....lol ;D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
kettlesd
« Reply #24 on: April 06, 2007, 09:53:07 AM »
Your local Dollar Store. Pick up a couple picninc mustard/ketchup bottles. You cut the tip as fine as you want. While your there pick up a trigger spray bottle for soaking large pieces.
ATF and Acetone does work good. ATF, Acetone, Mineral Sprits and kerosene in equal parts works even better. It was designed as a solvent at Frankford Arsenal for government firearms. Its called "Ed's Red". Fellow shooters here will know of it. Its cheap, dissolves carbon and penetrates very well.
