Author Topic: High flowing petcock question??  (Read 1147 times)
Offline yd72
« on: April 04, 2007, 08:42:28 PM »
Anybody have problem with high flowing petcock fit into a stock carbs before, like a honda cb350f bike ? Will there be any overflowing problem?? What kind of problems will I encounter?
Offline wardmoto
Re: High flowing petcock question??
« Reply #1 on: April 04, 2007, 08:54:45 PM »
Your flow of fuel is dictated by the engine, throttle position, load, carbs/jets, RPM  etc.  A  Honda engineer figured all this out 30+ years ago.  The bottle neck of the system are these variables.  As long as the petcock or petcocks flow a small degree more than that worst case max flow scenario as dictated by the variables, you are cool.  The bowels fill up and the float needles shut off the flow (all properly adjusted of course) and that is that.  I replaced my stock petcock with 2 after market jobs on my CR 750 glass tank.  They are 1/8 inch ID and the bike has V stacks and open un-baffled 4 into 4 meggas with 84 main jets.  The petcocks keep up fine to 10K rpm.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
