Author Topic: CB750 Kick start lever  (Read 1548 times)
chrisf
« on: April 05, 2007, 05:47:39 AM »
Does anyone know if the kick start lever will fit on a CB/CL350 shaft--i.e. is the diameter and spline count the same on the two bikes? The reason I ask is because the CB750 uses a swing-out mechanism near the kicker shaft. It will take some fabrication, but if it will fit, I think I can make it so it swings out enough to clear the brake pedal on the rearsets.
--Cheers, Chris
