Author Topic: Has anyone measured their rear wheel bearings and shaft  (Read 754 times)
Offline rhinoracer
« on: April 07, 2007, 02:07:53 PM »
I need replacement bearings, the old ones are stamped 304S. Cross referencing gives me 52x20x15mm size.
I measured the bearing ID (Bore) and it measures 19.94mm
The axle shaft measures at 19.85-19.91mm
The axle shaft slips into the bearing but there's no sideplay, in other words it fits snug.
I tried fitting the axle shaft into the caliper set at 20mm and it fits loose.
My question is: Are 6304 bearings the proper size, or are OEM bearings specially fitted.
« Last Edit: April 07, 2007, 02:11:10 PM by rhinoracer »
Baja native.
Offline nippon
    • Classic Cycle City
Re: Has anyone measured their rear wheel bearings and shaft
« Reply #1 on: April 07, 2007, 02:53:09 PM »
6304 bearings will fit the rear wheel perfectly.
nippon
