Author Topic: CB400F carb o-rings  (Read 867 times)
cmau75cb400f
CB400F carb o-rings
« on: April 07, 2007, 03:43:43 PM »
Does anybody know the size of the inlet tee o-rings for the carbs?
I did a search and did find info for the main jet, etc, but no info
on the fuel inlets.
Thanks
Curtis
Offline Kevin400F
Re: CB400F carb o-rings
« Reply #1 on: April 07, 2007, 04:59:59 PM »
1.9mm x 5.8mm
Do you have a supplier nearby?  I can sell you a set if you're interested.
Kevin
Offline wardmoto
« Reply #2 on: April 08, 2007, 06:38:06 AM »
Kevin hooked me up...work perfectly...be careful with those cheesy plastic interconnects.
03 Suzuki SV 1000S
86 Suzuki GS 550ES
72 Honda CB 350K
72 Honda CB 350F
72 Honda Cb 350F cafe
Offline Kevin400F
« Reply #3 on: April 08, 2007, 06:59:31 AM »
I recently purchased a mini-lathe, which should arrive early this week.  I plan to produce and offer replacement fuel interconnect tubes, probably of brass.
Kevin
