Author Topic: installing cam on 750  (Read 1228 times)
Offline JP
« on: April 11, 2007, 12:35:21 PM »
Searched, all I found was a bunch of timing posts for ignition.  I need to know where to start on actually installing my cam back in place after a rebuild.
I'm used to single cylinder stuff where I just faced the cam upwards, turned the engine to TDC, and viola!  Finished!
But the 4 cylinder stuff is a little more tricky.  Can you guys tell me the process.  I should be able to pick up on it with just a brief overview.
Thanks in advance,
JP
Rockers Unite!  I want to start a Ton Up/Rockers bike club around the Atlanta area, who's with me?  Send me a message.
Offline scondon
  • Mmmm......tasty bugs
Re: installing cam on 750
« Reply #1 on: April 11, 2007, 01:12:10 PM »
     Set engine to Top Dead Center on 1&4( "T" mark on timing plate ).  Install cam so that key notch on the end of the cam is at "12 o'clock" position and slot is paralell to gap between cam tower lower bearing and upper bearing. Hope this is clear, manual states it better.
Offline JP
« Reply #2 on: April 11, 2007, 01:54:23 PM »
Thanks Scondon,
That was perfect.  I know exactly what you are saying.  What I was confused on was which piston would be at TDC, I figured lining up the cam would be similar to others that I have done- and it is.
Thanks again and wish me luck,
JP
Offline Jonesy
  • Shop Rat
« Reply #3 on: April 11, 2007, 02:59:06 PM »
Offline scondon
« Reply #4 on: April 11, 2007, 03:15:36 PM »
Thanks Jonesy, that is what I meant to say ;) ;D
Offline Jonesy
  • Shop Rat
« Reply #5 on: April 11, 2007, 03:19:16 PM »
Actually, you said it quite well...
Offline scondon
« Reply #6 on: April 11, 2007, 03:31:47 PM »
Thanks again :)  It is always best to have all the supporting info though, and the pics and diagrams as well ;) ;D
« Reply #7 on: April 12, 2007, 05:06:05 AM »
Treat it as four seperate singles and it dosenrt matter which of 1& 4 is at the top as they both are and the firing order aint determined till the cam is in, or to put it another way pick a cylinder to put at TDC then face the cam lobes for that cylinder correctly
Offline JP
« Reply #8 on: April 12, 2007, 07:03:10 AM »
Good point bryan, it never even occured to me to treat each cylinder as an individual.  And thanks for the post jonesy, deffinately will help to clear up any issues I may run into.
JP
