Author Topic: Another carb problem  (Read 784 times)
Offline david 750f
  • 1976 CB750F
« on: April 11, 2007, 10:46:40 PM »
Checked in the FAQ's and could not find anyone that has had a similar problem..
Got a little overzealous with the air pressure when I was cleaning out the carbs…Any idea what the hole restrictor does that vents to the atmosphere?? If you look at the photo, the hole to the right of the main jet has a brass insert with a tiny hole.
The hole to the left of the main is missing the brass insert, it also vents to the the other carb..The picture is for the left inner carb.  The inner carbs vent to each other as well as to the atmosphere..can I run the bike like this???
Any insight??
1976 CB 750F
Re: Another carb problem
« Reply #1 on: April 11, 2007, 11:16:11 PM »
 :o My insight is blurry  :o
Offline david 750f
  • 1976 CB750F
« Reply #2 on: April 11, 2007, 11:20:23 PM »
Sorry about the picture, I will post a clearer one later...
Thx
1976 CB 750F
« Reply #3 on: April 12, 2007, 12:21:24 AM »
TTThhheeeyyy   sssaaayyy   aaa   pppiiiccctttuuurrreee   iiisss  wwwooorrrttthhh   aaa   ttthhhooouuusssaaannnddd   wwwooorrrdddsss... TTThhheeeyyy   sssaaayyy   aaa   pppiiiccctttuuurrreee   iiisss wwwooorrrttthhh   aaa   ttthhhooouuusssaaannnddd   wwwooorrrdddsss...  TTThhheeeyyy   sssaaayyy   aaa   pppiiiccctttuuurrreee   iiisss wwwooorrrttthhh   aaa   ttthhhooouuusssaaannnddd   wwwooorrrdddsss...
HHHooowww   mmmaaannnyyy   wwwooorrrdddsss   iiisss   aaa   bbbllluuurrryyy   pppiiiccctttuuurrreee   wwwooorrrttthhh??? HHHooowww   mmmaaannnyyy   wwwooorrrdddsss   iiisss   aaa   bbbllluuurrryyy   pppiiiccctttuuurrreee   wwwooorrrttthhh??? HHHooowww   mmmaaannnyyy   wwwooorrrdddsss   iiisss   aaa   bbbllluuurrryyy   pppiiiccctttuuurrreee   wwwooorrrttthhh???[/i]
Offline jtb
  • An unlikely
« Reply #4 on: April 12, 2007, 05:30:44 AM »
Lloyd, Get off the coffee, NOW! ;D ;D ;D
1977 CB750F
1985 V65 Sabre
