Author Topic: Home made rearsets  (Read 4316 times)
Offline jonbuoy
    • My rebuild:
Home made rearsets
« on: April 12, 2007, 03:02:13 AM »
As I'm too tight fisted to shell out for Raasks or Tarrozi rearsets I'm having a go at making my own.  I bought a set of NOS footpegs off  Rusty Riders on Ebay - very cheap they still have stock as well.  Most of the rest I have scrounged - they are made from 5mm ally plate, I drew an outline onto the plate-  roughly cut around them with a hacksaw and tidied them up with a bastard file, I bent them using a vice and a crescent -  then finishing file then polished up in the usual way.
The shaft running through them is made from some stainless tubing I found in a scrap bin of a local company that makes thermocouples for the dairy industry - it fits nicely over a 3/8 bolt - not a perfect bearing fit but pretty close.  I drilled out a hole in the shifter lever the same size as the outside diameter of the stainless tubing - heated the ally and tapped the tube in.  I have some uber strong locktight that I will use when I am happy with the final fit.
Luckily I already have a big ally plate to mount these on with the F frame, I scrounged another piece of thick wall stainless tube and tapped a 3/8 thread into it then fitted it into the ally plate on the frame itself - its not such a tight fit so I used some locktight sleeve lock to hold it in.  The pegs are already threaded with a 3/8 hole so I just had to cut a stainless steel bolt down to size leaving a small section of unthreaded stainless and  then thread the other end  - this bottoms out in the footpeg and will be locktighted in place.  A locknut on the rear of the plate and some stainless washers control the slack - its not bad - less slack than in previous factory rearsets I have had on other bikes.   I'm hoping they will wear well - its stainless onto stainless.  I'll update when I get the engine back in the frame.
The pictures should make more sense than my write up.
Offline cben750f0
Re: Home made rearsets
« Reply #1 on: April 12, 2007, 03:11:59 AM »
lookin good mate, keep us up to date with the progress, never know you might have to go into busyness!!!LOL
peace
Offline jonbuoy
    • My rebuild:
« Reply #2 on: April 12, 2007, 03:14:37 AM »
I already have a spline to fit over the gearshifter, for the brake side I have cut off my old pedal leaving just the clamp for the brake spline - will braize a plate with a hole for the linkage onto it.  I have made the brake lever slightly longer and wider as it will be taking more strain - I will try and get some thicker walled tubing as well.
Offline jonbuoy
    • My rebuild:
« Reply #3 on: April 12, 2007, 03:16:47 AM »
pictures of brake lever
Offline jonbuoy
    • My rebuild:
« Reply #4 on: April 12, 2007, 03:19:18 AM »
peace
Ha thanks I would be broke if I did this for a living - taken me more time than I like to think about.  ;D
Offline cben750f0
« Reply #5 on: April 12, 2007, 03:23:28 AM »
yeah feelin ya on that one... have gone back to uni at the ripe old age of 32 and it takes me an age to think about stuff.... doin a great job, and it helps that you have the spline already sorted, that would have been a bugger to have to make (am a fitter and turner by trade)....
cant wait to see the end result...
peace
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #6 on: April 12, 2007, 07:45:29 AM »
Nice job.  I have been considering making my own rearsets for my 350F and now I have some ideas.  Thanks.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #7 on: April 12, 2007, 08:44:35 AM »
I was gonna make my own for the CB450, but I just found a set offa 2001 GSXR 1100 for $100 at a crotchrocket junkyard.I am in proccess of making them work at the mommet (almost done). I will have under $150 once they are complete..
Offline jonbuoy
    • My rebuild:
« Reply #8 on: April 12, 2007, 01:54:24 PM »
peace
I'd like to go back to school and pay attention this time  ::)  I just need to find me a wealthy old lady to support me  Ha ha.
Cheers
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #9 on: April 12, 2007, 02:30:39 PM »
          I agree, very nice job on the rearsets. ;) 8) Anxious to see the finished product and I'm sure you are too. ;D Keep up the good work there.
                                                Later on, Bill :) ;)
Member # 1969
Offline zanzara
    • the hall of photos
« Reply #10 on: April 12, 2007, 02:37:04 PM »
I was going to do exactly what you are doing with the aluminum. I was just worried about the pedals twisting especially the brake, under use. I went with pedals from the scrap yard. I will be interested in seing and hearing about the results. look nice though. You are atleast past the point of no return.
chrisf
« Reply #11 on: April 18, 2007, 05:55:16 AM »
Here is what I ended up doing in 1/4" 6061-T6. The heal part is $15 aluminum BMX pegs from eBay, the toe portion is a $7 piece of knurled 6061-T6.
I'm making the brake pedal now.
--Chris
Offline bill440cars
« Reply #12 on: April 18, 2007, 07:45:24 AM »
         Man, LOOKING GOOD!!!! You are really giving some of us some really good ideas on the rearset thing and I can tell you that it is definitely appreciated! ;) 8) ;)
Member # 1969
Offline jonbuoy
    • My rebuild:
« Reply #13 on: April 19, 2007, 01:04:21 PM »
Ah nice - if only I could get access to a knurler!
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #14 on: April 19, 2007, 01:41:07 PM »
Jonbuoy,
I've got a knurling tool for my lathe, maybe I could help you out. PM me if interested.
Jinx
–Captain Horatio Hornblower
www.thehairynickel.com
Offline Chris Liston
« Reply #15 on: April 19, 2007, 01:58:03 PM »
Where would be a source for spacers.  I've got a pair of CBR 954RR rear sets that I plan on using.  I know the ohiocafe had to use 1" spacers to fit his CBR sets on his cb.  Not sure on the 550 though.  But if I do where would be a place (online or local) that they could be gotten?
1976 CB550F Cafe in progress
Offline zanzara
« Reply #16 on: April 19, 2007, 04:11:38 PM »
I know I have seen them at your neighborhood hardware store (not the big box) in different diameter holes in chrome steel. Cost an arm and a leg but look nice.
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #17 on: April 19, 2007, 04:15:04 PM »
I can help you out with some spacers pretty easily...just need dimensions. PM me if interested.
Offline jonbuoy
    • My rebuild:
« Reply #18 on: April 21, 2007, 03:33:36 AM »
Jonbuoy,
Jinx
Hey thanks Jinx, I live in New Zealand are you in the States?
