Author Topic: Bringing a 750 K1 back to life  (Read 2239 times)
Offline Laids
Re: Bringing a 750 K1 back to life
« Reply #25 on: March 21, 2025, 01:03:01 PM »
What a great project! Also, the picture in the gigantic shop, I'm jealous.
Following
Well the snowmobile season is officially over here in Southern Ontario...
What snow machine do you have?     I rode a buddies El Tigre years ago, that thing was fast!
2017 Skidoo renegade 600 and 2015 1200 4 stroke, buddys are riding new stuff, 900 turbos etc
Offline Laids
« Reply #26 on: March 24, 2025, 03:45:12 PM »
Engine is back together. The spare parts that came with the bike included 2 complete gasket sets, a 76F engine and new  stock Honda rings. The rings were 392 but as far as I can tell they fit the 300 pistons. I was tempted to use the 392 pistons as they were nice and clean. The difference to the 300 pistons is noticeable with a much larger chamfer at the top edge. I decided though to use the original pistons to keep it original. The 392 rings had the 3 piece oil rings, I read some have had issues with installation so I was a little concerned. I found if the Centre ring goes on first the other 2 scrapers fit fine. Cylinders were honed and checked ring gaps, a few were a somewhat wide but I thought good enough, I know others here might have more stricter tolerances.
Other than the usual chain tensioner flopping back a few times and backing off everything went smooth. Torquing down the head it started to pull the studs out on about half the studs before reaching values. I left it overnight and not knowing what to expect went back at it the next day. Everything torqued up fine after that.
The valves and seats were lapped and went back to their original locations. As per my last engine , forgot the valve seals, only had to redo 4 this time though. Top end went together with no helicoils necessary.
Starting on the carbs next, number one carb is the worst. I’m thinking the bike must have been on a side stand for while full off gas to be this grotty while the others were fairly clean. When I inspected that float  found a hole .
Offline BenelliSEI
  • 1969 cb750
« Reply #27 on: March 24, 2025, 06:06:02 PM »
That’s one heck of a hole!
Online newday777
« Reply #28 on: March 24, 2025, 06:12:01 PM »
I have a brass float if you need a replacement
Stu
My current rides
Prior bikes....
Offline Laids
« Reply #29 on: March 25, 2025, 06:47:54 AM »
Thanks but one of the other brass floats is dented, so would need 2. I have a set of single pull carbs but am reluctant to steal from them. I have quite a few plastic floats so will use plastic, not sure if combining brass and plastic would be a good idea. I couldn’t find any brass floats on line, I guess they have been replaced with plastic.
Online newday777
« Reply #30 on: March 25, 2025, 07:21:27 AM »
You probably shouldn't mix them, just replace them all with the plastic.
« Last Edit: March 25, 2025, 12:49:46 PM by newday777 »
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #31 on: March 25, 2025, 12:48:04 PM »
Truthfully, I’m running one plastic with three brass in my K1 (emergency fix that never got corrected) and it doesn’t seem to hurt…..
« Reply #32 on: March 26, 2025, 12:12:42 PM »
The brass floats will make the float-bowl level slightly 'deeper' than with the plastic ones, about 1mm difference is all.
The plastic floats came about to help stop side-stand-piddling on hot days, and later became the cheaper ones to make, during the K2 era.
(For performance buffs: use brass if you can, they tend to keep the bowls deeper while riding, compared to plastic ones.)
Link to website: SOHC4shop.com  (Note: no longer at www.SOHC4shop.com, moved off WWW. in 2024).
Offline Laids
« Reply #33 on: March 27, 2025, 06:32:01 AM »
Good to know
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #34 on: March 27, 2025, 07:37:59 AM »
Not sure I understand why they make a difference, is it the weight making them react differently to changing bowl depth?
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #35 on: March 27, 2025, 09:51:48 AM »
It's the material: the brass ones are lighter than the plastic ones and react in a more lively way while bumping along on the pavement. They result in actual float levels slightly higher while riding, but lower or the same as plastic when sitting still. The US DOT leaned on Honda in 1971 about this issue, trying to say that the deeper-while-rolling was making the bikes emit more pollution. Since it's a 'political' sort of thing I haven't talked much about it in these forums 'cuz we're not supposed to get 'political'. But it IS the truth, so there is that edge to it...I made note of this in several places in my upcoming book, which caused no end of grief for Honda in the CB500/CB550 carbs.
Offline Laids
« Reply #36 on: March 27, 2025, 02:19:34 PM »
Moving forward, the carbs are basically together, just waiting for needles and seats. I have a bunch of extra plastic floats so picked out the best ones. I finally bought a ultra sonic cleaner last year, always borrowed a friend’s until he moved away. It’s a 22 litre, really didn’t have to be that big but it seems to do a good job. Can easily get a rack in with room to spare. I have used the extreme Simple Green for aircraft, mixed with water, after use poured into a 5 gallon bucket and use again until too dirty.
The oil pump was next. I’ve done about 4 in the last 4 years, but I have never been able to get one completely apart, only the 2 springs and seals. I usually can get some of the JIS screws out but not all. Maybe there’s a trick, so far I give up after checking the gear to feel some resistance then think ‘good enough’.
Next is the front brakes.
Offline BenelliSEI
  • 1969 cb750
« Reply #37 on: March 28, 2025, 06:00:38 AM »
Looking good, lots to do!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #38 on: March 28, 2025, 07:44:53 AM »
Good progress
1973 CB 750 K3
Offline Laids
« Reply #39 on: April 10, 2025, 07:32:26 AM »
Engine is now painted and ready to be put back in. Starting on the gauges now to replace the faces. The gauges were not on the bike when I got it but in a box with various other gauges and new faceplates. It did have replacements for the K1 but on examination I can see that someone had written on top of them with pressure , it can only be seen when you hold it on an angle. I’m not sure whether to use them. If so will the impressions show when it is backlit.
The other issue is in both the Speedo and tach, the little metal pieces that are in front of the backlit bulbs have broken off and we’re loose when I opened up the gauges. I was tempted to leave them out but that will change the lighted look I think. To reattach them I can only think of using something like JB weld. I can foresee a mess there.
To finish off , the chrome backs that came with everything are 2 Speedo backs, what a cluster@####.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #40 on: April 10, 2025, 07:47:10 AM »
Gauges are a tough item. Can you buff off the impressions or did I misunderstand where the impressions were? Why would someone do such a thing?
1973 CB 750 K3
Offline BenelliSEI
  • 1969 cb750
« Reply #41 on: April 10, 2025, 09:07:30 AM »
Honda sells replacement back plates for the instruments. They are one part number as they fit both. Ithink I have a new set if you need them.
Offline Laids
« Reply #42 on: April 10, 2025, 09:23:07 AM »
The impressions look like a phone number and they are on both. Screw it, I just ordered new faces from Yamiya. Not worth it getting it back together and having to look at that.
Offline Laids
« Reply #43 on: April 10, 2025, 09:41:42 AM »
That makes sense about the same part number. The previous owner ordered them.
« Reply #44 on: April 10, 2025, 09:55:57 AM »
 Do those have a peel off plastic covering? Some of mine did.
Offline Laids
« Reply #45 on: April 10, 2025, 01:39:18 PM »
It’s official, I’m an idiot, lol. I went back out to the garage to see if there is a plastic cover , I tried before but this time was able to pull an edge. It probably has been on for 20 years, anyway it pulled off, voila a perfect face. Thanks Don  ::). Now the only thing that bothers me is the white backing while the original is a thicker green opaque plastic. I had considered cleaning up the original face and glue the new face on. The original is about 1/8” thick and the new face <1/16”.
Offline BenelliSEI
  • 1969 cb750
« Reply #46 on: April 10, 2025, 03:21:59 PM »
How hard was getting them open? I have a spare set (K1) I should do…….
Offline Laids
« Reply #47 on: April 10, 2025, 03:56:31 PM »
I got new crimp rings and cut the old with a dremell. You can pry the old off and reattach but is a bit of a hassle to not damage too much. I’ve only done one other set of gauges before and they were non stock faces.
Offline BenelliSEI
  • 1969 cb750
« Reply #48 on: April 10, 2025, 04:51:48 PM »
And crimping on the new ones?
« Last Edit: April 11, 2025, 06:19:09 AM by BenelliSEI »
« Reply #49 on: April 10, 2025, 05:20:23 PM »
Uh...you might have to stand in line for that one...
(Don't ask, I never tell...).
