Author Topic: Couple noobie questions  (Read 1057 times)
Offline feliz
« on: April 12, 2007, 03:26:37 PM »
Sorry for asking such elemetary questions but turned up nothing in a searh.
I've finally got the points and timing set up smack-on using a dwell meter and strobe light, it will go quicker next time. My question is, I haven't used points grease in 30 years anad can't find any in the stores. What is everyone using and where do you get it, maybe everyone is using a substitute lube of some kind, I guess as long as it's high temp?
Next question is I would like to tackle the carb sync and I'm willing to buy gauges but where are the carb fittings available? I'm talking about the ones the gauge hoses would attach to. Thanks.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline Gordon
  • 750K1, 550K2
Re: Couple noobie questions
« Reply #1 on: April 12, 2007, 03:30:49 PM »
I believe Harley shops sell small tubes of something called point cam grease, but I've always used a very very small dab of lithium grease.
A decent set of carb synch guages will come with the adaptors to fit them to your carbs.
Offline 736cc
« Reply #2 on: April 12, 2007, 03:47:56 PM »
Denis Kirk sells carb sync 5mm adapters
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: April 12, 2007, 04:19:31 PM »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline feliz
« Reply #4 on: April 12, 2007, 04:26:51 PM »
Another source for the 5mm vaccum port barbs
And a lot cheaper. Thanks.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
Offline DrMark
« Reply #5 on: April 12, 2007, 04:31:26 PM »
JC Whitney and Z1 Enterprises are also good sources for synch gauges. Z1 is also a member of this forum.....keep the money in-house...LOL
1978 CB550K
1983 CB650SC Nighthawk
Offline feliz
« Reply #6 on: April 12, 2007, 04:41:01 PM »
Thanks. They offer a set of Emgo gauges with hoses and adapters for less than $50, can't beat that.
They don't specify but I'm assuming the adapters are 5mm, anyone know?
Thanks to all the responders.
feliz
Current bikes:
05 Ural Patrol
CB750K1, K3, K4
08 Aprilia Shiver
