Author Topic: '72 500 Four 9.9 Volts No Spark  (Read 2090 times)
Offline Dr. Frankenstein
Re: '72 500 Four 9.9 Volts No Spark
« Reply #25 on: March 24, 2025, 09:41:02 AM »
Here's what I just did - I got everything sorted the way you said, but still I got nothing. See pic. I followed all the testing procedures from Common Motor Collective on this video here - and it looks like BOTH my coils are defective. I feel a strongly worded letter to the vendor coming on.
I also tested continuity through the points as seen in the video at 3:53, and my test light stayed on the whole time, so something is definitely not right here. It did pass all the other tests except the functionality of the ignition coil test at 10:22 - I just can't believe that ALL my coils, points and condensers, which are NEW, are all bad. That makes me think it's something I'm not doing right, because in 25 years of refurbishing bikes I've never had that happen, usually it's something stupid I've overlooked or forgotten - still, I guess it could happen!
« Reply #26 on: March 24, 2025, 10:00:27 AM »
If the test light stays on either the points are not opening, the wiring to points is shorted to ground or the wiring of points, condenser lead is wrong
« Reply #27 on: March 24, 2025, 10:16:59 AM »
Hmmmm...."or the wiring of points, condenser lead is wrong." I need to investigate that a bit more...on the points that were on the bike originally, the two leads for each condenser were touching the prong for the wire so I put them in that way - I thought that looked weird to begin with...those two prongs for the points and condenser should be separated when they go back in, yes? This bike sat for years in a shed, so I have no idea what the PO may have done.
Update - I am happier to report that seems to have been the problem - I separated the prongs on the points and got a pretty weak spark on 2, 3 and 4, but #1 was a no-show...I've been cranking the bike for a bit, so the voltage has probably dropped some. I'll recharge and test again.
« Last Edit: March 24, 2025, 10:35:06 AM by Dr. Frankenstein »
Offline denward17
« Reply #28 on: March 24, 2025, 10:19:41 AM »
Hmmmm...."or the wiring of points, condenser lead is wrong." I need to investigate that a bit more...on the points that were on the bike originally, the two leads were touching so I put them in that way - those two prongs for the points and condenser should be separated when they go back in, yes?
I don't think it matters, just make sure they are not touching the bracket of the points.
« Reply #29 on: March 24, 2025, 10:35:35 AM »
See 'Update' above...
I'm pretty sure these are 3 Ohm coils; 5 ohm coils would give me a hotter spark, yes?  Also, I went back and checked again, and I DO have weak spark through #1, but I also am getting a tingle through the Start switch...granted, the plugs are all out, and those acts as the ground - but is something shorting here? I've never felt electricity through the kill switch before. It's not bad, but you can certainly feel it! Tingle Tingle Tingle!
« Last Edit: March 24, 2025, 10:46:00 AM by Dr. Frankenstein »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #30 on: March 24, 2025, 11:25:06 AM »
Great to hear that you are making progress. Do you have the OEM Points and Condensers?  If yes out them back in.
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #31 on: March 24, 2025, 11:27:40 AM »
One of the reasons I changed them was because they were pretty pitted and sparking - of what benefit would this be?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #32 on: March 24, 2025, 11:47:29 AM »
The aftermarket ones are poo.   If they are sparking it's a sign the condenser is bad. Try and find some good or NOS originals.
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Offline Ozzybud
  • Honda Lover
  • Honda Lover
Offline newday777
« Reply #35 on: March 24, 2025, 01:02:43 PM »
Neither of those are for your 500/4
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #36 on: March 24, 2025, 01:04:08 PM »
Get them from the link in post 14. Save yourself a lot of trouble and wasted money.
Stu
My current rides
Prior bikes....
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #37 on: March 24, 2025, 02:23:59 PM »
My mistake.. not sure what Schematics/part numbers I grabbed off CMSNL
« Reply #38 on: March 24, 2025, 02:38:36 PM »
If you get the complete plate it even has the wires that connect by the rear brakelight switch so you cant get the points/condensers/wires position wrong
« Reply #39 on: March 24, 2025, 02:40:34 PM »
Oh, where's the fun in that?? ::)  Speaking of which, while we're on the subject of wiring, can somebody please send me a pic of the proper connections for the blinkers in the headlight bucket? My right-rear blinker is hooked up correctly in the back but doesn't want to work with the right-front. The bulb is fine, and I've got continuity through all the wires of the right rear blinker, from the rear connections up to the headlight bucket, but it doesn't want to come on and I think it's a wrong connection, but I don't know where.
« Reply #40 on: March 24, 2025, 02:47:12 PM »
If its a US model the front has 2 wires and a 5/21 bulb, the wires are blue and blue with white stripe for one side the orange and orange with white stripe for the other, dont ask which is rh or lh i can never remember
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #41 on: March 24, 2025, 03:27:27 PM »
The us model CB500 in 1972 did not have running lights so there is only light blue for the right and orange for the left.
If there is 2 wires going to the blinker the other one is green for the ground.
here is a pic of my CB350F  should be similar. mine are grounded thru the headlight ears and bolts. So 1 wire
« Last Edit: March 24, 2025, 03:30:00 PM by Ozzybud »
