Author Topic: ..........Carburettor FUEL LEVEL manometer  (Read 1289 times)
Offline Michael pinfold
« on: March 22, 2025, 12:06:11 AM »
After having carbs off several times from  ,my honda 400f  engine and getting no where fast, I decided the last thing to try was to look at  fuel levels inside the bowls of the carbs,  the Rich running seemed to point to fuel level problems,  as I had eliminated all other variables !  The problem was to make a small  connection into the base of the carb with the drain plug removed .I didnt want to modify the little Honda brass drain screw  ,I went looking for a screw of the same thread  with a vision of drilling up the centre  connecting clear  tubing and thus screwing it in and see the actual level of fuel in the Float  bowls . I read that the correct level was 3-4 mm below the height of the junction between the bowl and carb  body , anyway to cut a long story short, I found that the metal threaded part of a Female BANANA socket  , is the exact same thread  and it is hollow  . !! Banana plugs and sockets are very common in the electronics industry and just about any electronics shop will probably have them , you require the chassis mount female connector  that you solder a wire to...look at my picture  of one connected to tubing  you will have to drill a small hole through the end the 3mm tubing pushes onto , this connects to the large hole up the centre  . use the same nut  with a small "o" ring to provide a fuel tight seal ,it screws in about 8 turns   Dont need to sacrifice a brass fuel bowl drain screw.  not sure if this size thread is on other Honda 4  carbs !  cheers  Mike
