Author Topic: DELKEVIC FOUR into ONE EXHAUST ADVICE REQUIRED  (Read 395 times)
Offline Honda750!!!
« on: April 02, 2025, 01:01:22 PM »
Guys, I am opting for the DELKEVIC FOUR into ONE exhaust set up for a 1972 CB350F that we just picked up. I need some advice on the carburetion side of things, as far as setting up the carburetors to run correctly with this exhaust .............. Any advice much appreciated !!! Thank you, Mark in LAS CRUCES, NEW MEXICO
Offline denward17
Re: DELKEVIC FOUR into ONE EXHAUST ADVICE REQUIRED
« Reply #1 on: April 02, 2025, 02:29:36 PM »
I would think no jetting required, however, I'm not familiar with the 350 as much.
« Reply #2 on: April 03, 2025, 08:26:27 AM »
 I had a 400F that had pod filters and a supertrapp muffler, it wanted some choke to run well. I put the stock intake back on it and that was all it needed. I'd try it and if it has any bog or flat spots try a little choke, if that helps add jet or needle to help that rpm range.
Offline carnivorous chicken
« Reply #3 on: April 03, 2025, 09:24:09 AM »
From what I have heard with both 400F and 350F they are bolt on and go... But regardless, if you are going to run them best to get them on and see how it runs before trying to buy jets in advance -- you can always get them later if you think you need to.
« Reply #4 on: April 03, 2025, 02:47:30 PM »
Don't re-jet until you get it running and only if you need to
Offline WhyNot2
  • I'm finally an
« Reply #5 on: April 04, 2025, 12:37:43 PM »
I got the same on my CB350F and did nothing to the carbs,
before and after pics
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: April 04, 2025, 02:26:18 PM »
My totally stock ‘76 cb750F ran very well on stock set up.
Offline WhyNot2
  • I'm finally an
« Reply #7 on: April 06, 2025, 06:53:28 AM »
Yep, got them on my 75 cb750 as well.
She runs well.
