Author Topic: Final Generation of Billet blocks??  (Read 31059 times)
Re: Final Generation of Billet blocks??
« Reply #100 on: December 31, 2025, 04:47:23 PM »
I will be sending the blocks out for plating around 1/14/26. I need for folks to contact me as I have to pay for the plating upfront as I did for the pistons.....it's getting expensive for me and I need to keep my wife off my back.🙄😄
Offline Tracksnblades1
« Reply #101 on: January 02, 2026, 08:01:30 PM »
Mike
Sent you an e-mail New Year’s Eve…
Let me know when convenient..
TracksNblades…👍
Age Quod Agis
Offline denward17
« Reply #102 on: January 16, 2026, 08:01:30 AM »
Not affiliated with this group buy, but have a question:
The coating that is applied to cylinder block (Nikasil); is this for a racing setup only?
Meaning that it has to be re-plated again after so many runs, or is it as durable as the steel liner?
« Reply #103 on: January 16, 2026, 10:52:45 AM »
Harder than iron sleeves. The piston skirts will wear out first. And yes...it can be stripped an replaced if necessary (after cylinder damage caused by dropped valve etc.)
Offline willbird
« Reply #104 on: January 16, 2026, 11:39:57 AM »
I was really fascinated by your idea of putting aluminum sleeves into OEM blocks and then having the Nikasil applied, or that was what I thought you were talking about anyway.
I'd love to have a copy of your blueprints to see if I can carve one of your blocks from billet on my bridgepoort in the garage at home.
Bill
« Reply #105 on: January 16, 2026, 01:46:33 PM »
Bill
The aluminum sleeves in a stock cylinder is cool. Anything to help with heat dissipation. Your interference fit would have to by much at all with the sleeve flange there. Heat the block, freeze the sleeve and it would drop right in. As for the blueprints........ ;D
Offline willbird
« Reply #106 on: January 16, 2026, 03:22:00 PM »
Bill
I figured does not hurt to ask :-D, asking has produced wonders in the past :-).
Bill
« Reply #107 on: January 20, 2026, 07:13:51 PM »
Blocks will be at Millennium this Friday (barring some unforeseen weather event).🤣
« Reply #108 on: January 21, 2026, 09:14:07 PM »
 L0L, there is a predicted weather event. I've been seeing weather bulletins telling people to get off the road when the snow squall comes through, I'm not sure how far north the snow alert goes but the -50F wind chill warning extends to Wi. for sure.
 One forecaster said we could get between one and a hundred and seventeen inches of snow.
Offline newday777
« Reply #109 on: January 22, 2026, 12:52:10 AM »
With the cold air in place many are forecasting snow down through mid Texas over to the east coast of Georgia, up through New England, the 15° F forecasted for Sunday here in NH will bring the light powder snow production to upwards of 20"/1" water vapor values compared with the normal 10"/1" value and how far north the storm center tracks(they still don't know where it will track or the outcomes!).
Even the written forecast from NOAA that the weather watchers get is talking to keep a big eye open with the deep cold wind chills into the -20° to -40° F here into northern NH, frostbite in short minutes possible. So yes definitely an EXTREME WEATHER EVENT......
« Last Edit: January 22, 2026, 01:14:54 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #110 on: January 22, 2026, 12:54:30 AM »
Mike
Did you put a million dollar insurance on each package??
Stu
My current rides
Prior bikes....
« Reply #111 on: January 22, 2026, 04:52:57 AM »
Mike
Not quite that much Stu.They certainly are  well packaged so we have that going for us. Should arrive there tomorrow....I'll check the tracking today. In the mean time I have to shag more firewood from the main pile to keep that stove cranking. Got plenty of pellets for the pellet stove.😉
Offline bigutah
« Reply #112 on: January 23, 2026, 10:18:57 PM »
Good things come to those who wait
« Reply #113 on: January 24, 2026, 09:10:54 AM »
They got there yesterday.😉
Offline newday777
« Reply #114 on: January 26, 2026, 07:43:08 AM »
Turned on YouTube just now after coming back in from shoveling out the 12"+ and this was there on
Stu
My current rides
Prior bikes....
Offline bigutah
« Reply #115 on: February 07, 2026, 09:04:50 AM »
awaiting that Gen 3 block……
Offline newday777
« Reply #116 on: February 07, 2026, 09:18:22 AM »
Did you bring it back with you?
Stu
My current rides
Prior bikes....
Offline simon#42
  • liverpool
« Reply #117 on: February 07, 2026, 12:56:15 PM »
Thats not the 250 replica its a 750 replica .
Offline bigutah
« Reply #118 on: February 07, 2026, 01:16:05 PM »
Who said it was to begin with? lmfao
« Reply #119 on: February 09, 2026, 09:37:41 PM »
 I've been shopping for a good quality ring compressor, or is it better to get two?
 I'm thinking the plan is slide all pistons in the bottom of the sleeves one at a time, then lower the center pair first, slide first pair of pins and clips in before all of the studs are inserted. Next the end pair, then the rest of the studs.
 Does that make sense? The last time I tried it all of the cylinder studs were in, and it wasn't very workable. It sure was easier to get the rings tucked in though.
« Reply #120 on: February 10, 2026, 08:53:03 AM »
I installed with the 4 center studs to start with.  Less obstacles.
http://forums.sohc4.net/index.php/topic,49438.msg1882792.html#msg1882792
« Reply #121 on: February 10, 2026, 03:34:55 PM »
  This one has been prepped for heavy duty studs so that process seems do-able.
Offline newday777
« Reply #122 on: February 17, 2026, 06:23:33 AM »
Gere ya go Mike, what you sent me yesterday
Stu
My current rides
Prior bikes....
« Reply #123 on: February 17, 2026, 06:27:24 AM »
Thanks Stu....I couldn't get it to post. Just have to get them bead blasted and they'll be ready to ship.😉
Offline newday777
« Reply #124 on: February 17, 2026, 06:29:28 AM »
😍 8)
Stu
My current rides
Prior bikes....
