Author Topic: Final Generation of Billet blocks??  (Read 30833 times)
LiveeviL81 and 1 Guest are viewing this topic.
Offline denward17
Re: Final Generation of Billet blocks??
« Reply #175 on: April 09, 2026, 08:08:57 AM »
To those that got the billet block:
When you start building could you start a thread with details please, curious to follow along.
Thanks in advance,
Dennis
« Reply #176 on: April 09, 2026, 10:49:44 AM »
  I have one on the way and am also interested to see how the other ones are used. I have a low mile crankshaft and crankcase, a Big Jay backcut F2 transmission and Carrillo rods but nothing photogenic. Other projects are going to keep me busy in the near future so I might not be able to get right on it.
  There are a few good cams in my stash but how they compare to a modern grind like the ones guys have recently dyno tested are keeping me wondering. Per has been very helpful sharing his dyno information which is solid data compared to my opinions, assumptions and old magazine stories. L0L.
Offline denward17
« Reply #177 on: April 09, 2026, 11:40:35 AM »
Understand.....
Does the backcut transmission gears only keep it from jumping out of gear?
« Reply #178 on: April 09, 2026, 01:47:20 PM »
Understand.....
It facilitates the gear engagement....helps the gears "suck" into each other.
Online PeWe
« Reply #179 on: Today at 12:03:33 AM »
Understand.....
I have only backcut trans for acceleration gear 2-4.
2nd typical slip out gear
4 too easy to nudge by foot during acceleration and fall into a false neutral which can be a pain to get out of.
I think there are racing versions that have deceleration cuts too?
« Reply #180 on: Today at 04:08:54 AM »
Understand.....
Yes...called "up and down" cut.
Offline denward17
« Reply #181 on: Today at 05:23:13 AM »
^Would anyone ever do the backcut of gears on stock power?
Online PeWe
« Reply #182 on: Today at 06:54:42 AM »
My almost stock  K2 (higher compression with Cruzinimage  K7 pistons (+0.50 mm)  has a good transmission without backcut. Not rounded gear dogs.
I feel a difference when I ride my K6 with backcut transmission.
Mostly to not make the mistake of pushing the 4th gear into false neutral  by a fat boot.
If you have a backcut trans to use, use it.
Or if you can get the job done for a good price when building an engine.
