Author Topic: Final Generation of Billet blocks??  (Read 13738 times)
Re: Final Generation of Billet blocks??
« Reply #75 on: August 08, 2025, 04:32:47 AM »
This will be interesting. I've done this before and I'll be honest 90% of these units go overseas. I don't care about that but  the reality is everybody wants one until they are finished and then there are crickets. No more of these....this is me doing my best for a bike I love so much. You would not believe all the interest when they are gone. Christ....you'd think nobody had a chance buy one. ;D ;D ;D
I used to run some group buys for custom Bullet molds. We would order minimum 25 units and typically 30 or more wanted one prior to order. We typically ordered a few extras. There was a steep price break at 100 quantity but we never ever had that many commit. I had 40 participants on one group buy and took a few C notes out of my own pocket and ordered (100). I just kept telling people over the next two years that I had a "few extra" and I would sell them one. Finally they all sold. Had people found out they would have been angry but they were not dipping into their own pockets to order (100) vs (40) of them.
Bill
I have to say things have gone much smoother this time around and I appreciate the fellas I've been working with. No procrastination. Doing a group by on the pistons/gaskets to save everybody some dough there too. I appreciate the commitment and prompt follow up from the guys.
Offline willbird
« Reply #76 on: August 08, 2025, 06:57:51 AM »
Bill
It makes sense to get all the exactly correct "stuff" really.
Bill
Offline denward17
« Reply #77 on: August 08, 2025, 07:26:14 AM »
I'm not on this train, but just curious, what size will these end up being?
>1000cc ?
Online newday777
« Reply #78 on: August 08, 2025, 07:58:30 AM »
>1000cc ?
Some will be 1026cc, 72mm pistons
Stu
My current rides
Prior bikes....
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #79 on: August 08, 2025, 06:16:02 PM »
PM sent. I hope there's one left!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline afkrejci90
« Reply #80 on: August 10, 2025, 06:06:45 PM »
Email sent
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
« Reply #81 on: August 13, 2025, 07:10:04 AM »
All the blocks have been sold.
Online newday777
« Reply #82 on: August 13, 2025, 07:11:49 AM »
Stu
My current rides
Prior bikes....
« Reply #83 on: August 13, 2025, 02:21:44 PM »
 So is there a popular formula for building a one liter 750?
« Last Edit: August 13, 2025, 02:35:13 PM by Don R »
« Reply #84 on: August 13, 2025, 02:26:59 PM »
Ported head with OS intakes, Megacycle 125-70 or comparable, good rods, HD cylinder studs, HD primary/cam chains and a primary drive rebuild with fresh rubbers. That's the basics in my book. I'd recommend good carbs like the Mikuni RS-34's are a very good idea as well.
« Reply #85 on: August 13, 2025, 02:34:46 PM »
I found a new set of Wiseco 70mm pistons that have had the pin moved up 3mm. These are meant to work with a 6mm stroker crank. and yield 1062cc's. These have XA rings and have a notable dome. They look like they would work well with an F2 head with some chamber modification. I'll post a picture in a day or 2. Anyway...I'd let them go for 450.00. If anybody is interested drop me a PM.
« Reply #86 on: August 13, 2025, 02:39:24 PM »
 I have a stroker crank but I'm not sure I'd risk a new build on it. I had it magged and the guy said it blew his mind until he realized it was a welded stroker, he said it had no sharp lines, just fuzzy lines where the welds overlapped. It was in an 1124 with a sunken sleeve.
« Reply #87 on: August 13, 2025, 03:08:08 PM »
 Here are some pics on this link. https://www.cyclexchange.net/Engine%20Parts%20Pistons%20Page/Stroker%20Pistons/Stroker%20Pistons.htm
Don....I had Marine Crankshaft stroke a crank for me. The one I sent was mint....like 2 balancing holes in it. They did a fantastic job and Stu can attest to that. I'll start a thread with my build. Got the F2 head back from Stetson with VJ etc etc...it also came out great. The porting sucks but it was done by an amateur. ;) ;D ;D
Offline willbird
« Reply #88 on: August 14, 2025, 09:03:54 AM »
Those pistons are NICE.
Bill
« Reply #89 on: August 14, 2025, 10:32:47 AM »
Mike, bigger welded inlet spigots? Or, the ported F2 inlets will due?
Smaller ex valves to leave room for bigger inlet valves like 35mm or what can be thrown in.
My ported heads, 300 (K6, K2) and 392 have all smaller IN spigots ID than my 32 mm carbs. Max 30mm.
Must be the limitation for more power that could be closer to 120 than 110whp with a bigger port head.
I heard about a swiss guy with a Billet block, 71.25 mm pistons, 125-70/75 and 120whp. Head with bigger welded inlet spigots.
Smaller ex valves for bigger in.
The clutch should keep it together too ;D
I read about Honda CB1100R 1983. 120hp on crank, 106whp @ 9000rpm.
70mm pistons, 1062cc.
This cc is what a CB750 gets with 70mm pistons and 69mm stroke.
The whp numbers feel familiar ;D
Torque 98 Nm at 6800rpm. 6Nm more than my K6. But the CB1100R wake up earlier.
A stroker crank might make an earlier torque curve.
https://www.motorcyclespecs.co.za/model/Honda/honda_cb1100rd_83.html
This is what you will get with 970 and up with 125-70/75 cam.  Ported head 33.5/34mm inlet valves.
Compression is vital. My K6 got 101whp with ca 200- 205PSI,
104-105/107whp DIN  215-225PSI. Cheap tester. Advanced cam timing affect it too.
Compression increased with thinner gaskets.
Started with base RCS 0.02",  head 0.04" MLS.
Then  0.03" head, later followed by 0.01 RCS.
Total 0.5 mm less chamber height  by gaskets -1.92cc on 70mm bore, -1.99cc 71.25mm bore.
I read about squish on the race forum where an austrailan race tuner wrote that about 1mm squish is a good number.
If piston outer flat area is flush with cylinder head gasket area without base gasket. Thin RCS + thin MLS makes 1mm.  ;) My 70 and 71.25 mm pistons have flat top domes and outer flat areas.
Domes for the 23.7cc chambers.
My engine with 125/75 runs very smooth and even. A good street bike.
I ordered a new 125/70 via Mike very soon after I installed the 125-75 and a few test rides. Must have one extra just for sure.
I doubt there is a better cam for this setup.
Plan B street cam an RC/DP295.
The flatslide carbs have a little bit too good throttle response.
I hope the dyno forum thread will get new posts next year. ;D
Edit:
Gas ported pistons?
I have not tested mine yet, lateral. They belong to my Billet block.
https://www.jepistons.com/je-auto-blog/gas-ports-in-modern-pistons/
« Last Edit: August 22, 2025, 11:13:22 PM by PeWe »
« Reply #90 on: November 01, 2025, 05:43:20 AM »
Good news....pistons will be here by the end of next week. I'll be picking up the manicured blocks early the following week. I good friend of mine does the finishing.....he is very good after spending years doing the finish work on F1 suspension valves.😉 Ordering the shipping boxes from Uline and have all the 2" foundation foam I use to ship the pieces to and from Millennium and the final destination. I'll post some pics of the pistons.👍
Offline bigutah
« Reply #91 on: November 01, 2025, 07:20:10 AM »
What mine is going in.
125/75 cam. The 33.5 stuff. Ported head.
Wanting to ride it long distance across the United States
Online newday777
« Reply #92 on: November 01, 2025, 08:04:00 AM »
A good aspiration to ride it across the country. I rode my K6 across the country 5 times in the 70s when I was in my 20s and had a good back.
I wonder if I can make my K5 or my F1 so my back can do longer rides like I can still do on my 08 goldwing????(I'm on a cross country rideabout right now seeing my kids and grandkids, in Vegas until Monday when I start the Vegas to Florida leg, then Florida to NH leg, hopefully before the snow flies.
Stu
My current rides
Prior bikes....
« Reply #93 on: November 01, 2025, 11:15:09 AM »
 I'm undecided which bike I'll put mine in, most likely my K0 that looks just like that pic since it has a K4 engine now then that motor can bring another bike to life, but I'm leaning towards the K1 Rat Race getting un-ratted.
  I've been told I look too old to be riding a lowered, lengthened, RC 4-1, rear sets, chopped fenders, mag wheels, double disc, fat tire, Mikuni carbed, K&N filtered K1. Makes me want to ride it more.
Offline bigutah
« Reply #94 on: November 07, 2025, 06:51:43 PM »
Patiently waiting for the big block gen 3
« Reply #95 on: November 07, 2025, 09:17:29 PM »
They do not think that you still ride a bike you rode in the 70's-80's? ;)
Dug it out from the rear end of  the garage.... ;D
« Reply #96 on: November 08, 2025, 05:42:52 AM »
Pistons arrived. Double wall boxes from Uline ordered yesterday. Going to Massachusetts this Monday....will be picking up the smoothed out blocks. I should be able to ship the blocks to Millennium right before Thanksgiving and will be requesting they be returned after Christmas.....I don't like shipping around Christmas time. I'll be requesting another deposit to cover the cost of pistons and plating.😉
« Reply #97 on: November 08, 2025, 10:35:35 AM »
 Is Millenium back in the nicasil business after the fire? A friend of mine didn't think they were yet.
« Reply #98 on: November 08, 2025, 01:32:49 PM »
When I spoke with Andy at Millennium several months ago he said they would be up and running about this time. They were plating a limited amount of cylinders.......mostly single cylinder off road engines. I have to call again next week to give them a heads up.....I'll let you fellas know what's going on.
« Reply #99 on: November 08, 2025, 05:00:34 PM »
 It's good to have an approximate timeline, thanks Mike.
