Author Topic: Break lines  (Read 997 times)
Offline Nol_one99
Break lines
« on: April 07, 2025, 07:42:04 PM »
Hi all! I am changing my front break line to a single cable but was confused on the size of the threads going into the caliper. Anyone know? (I have a 1977 cb750k7)
I plan on buying a custom line off of . . .
https://us.helperformance.com/custom-braided-brake-lines
I have an option to make the end for the break caliper a female swivel head that screws onto a detachable npt male end but I only get two size options which are
AN3 female with 1/8” NPT male
OR
AN4 female with 1/8” NPT male
I don’t know out of those which I should get or if I should just get the swivel male attached to the end of the line which has an assortment of sizes.
Any suggestions or advice would be very helpful!
Thank you!!
Re: Break lines
« Reply #1 on: April 07, 2025, 09:49:37 PM »
If you're going non-OEM for these important parts, I might suggest looking at Z1enterprises here:
https://www.z1enterprises.com/brake-and-brake-parts/brake-lines.html?product_list_order=name
I've rebuilt a number of these bikes using their parts. good quality, and that's mighty important for the stoppers!
Offline newday777
Re: Break lines
« Reply #2 on: April 08, 2025, 12:04:37 AM »
Welcome to the forum Nol_one99
The treads going into the K7 caliper are 10mm × 1.25
Be sure to go to the new members section and introduce yourself and your bike.
Stu
My current rides
Prior bikes....
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Break lines
« Reply #3 on: April 08, 2025, 07:40:37 AM »
My new brake lines are made of Monel (copper nickel alloy), they don't corrode, they only get a little patina. I think I got them from Yamiya.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Nol_one99
Re: Break lines
« Reply #4 on: April 08, 2025, 07:58:29 AM »
Well the reason I’m customizing my own is because I’m doing away with my break line splitter as I’m just got a headlight bracket that mounts the headlight from a bottom bold and the splitter is in the way. So I’m just going to do one continuous line to the caliper.
Offline Nol_one99
Re: Break lines
« Reply #5 on: April 08, 2025, 08:00:54 AM »
So would you recommend me just get the swivel make end as it has that size?
Compared to this second option which has those other sizes
Re: Break lines
« Reply #6 on: April 08, 2025, 10:47:03 AM »
doing that looses your front brake light is that legal in your state?
Offline Tracksnblades1
Re: Break lines
« Reply #7 on: April 08, 2025, 12:56:33 PM »
That’s a good question…
It’s called the Uniform Traffic Code on this side of the little pond…
Varies a little from state to state.. window tinting is one that comes to mind..
I wouldn’t disable the front brake light myself nor the front brake..but then there’s the old choppers,
No front brake or front brake activated rear brake light, but may still slip right through the cracks..?
With the emphasis placed on the effectiveness of the front brake compared to the rear brake by the Illinois Secretary of State during Motorcycle driver license endorsements L or M examination testing. I doubt a defective front brake attivated light or missing front brake would pass the driving test. When my son added his Class M endorsement to his license they checked that everything attached was functional before he could use the motorcycle in the driving part.. one of the requirements of the driving course was stopping from a certain speed within a measured distance with the front brake…but in the book hand signals during the day are still legal..? 🤔
All this “BRAKE” code is causing me to need to take a BREAK….🤔
Age Quod Agis
Re: Break lines
« Reply #8 on: April 08, 2025, 01:01:35 PM »
You could use a later model master with integral mechanical switch or even a banjo bolt adapted to work a light, i have seen those but not sure if i trust them!
This side of the pond you must have 2 seperate braking systems and both must operate the brake light, hence even on linked systems usually one front  disk is worked by lever on bars whilst rear plus other front worked by foot
Offline Nol_one99
Re: Break lines
« Reply #9 on: April 08, 2025, 03:00:16 PM »
The new master cylinders I got have a switch in them! So the wiring will be fine.
Re: Break lines
« Reply #10 on: April 09, 2025, 07:19:32 AM »
Not familiar with that vendor you are using but Apex Brakes can make whatever you need.
http://www.apexbrakes.com/custom.asp
I would not recommend a "swivel head" as that is just another possible leak source.  I hope you plan to restore your caliper too!
PS.  "Brakes" not breaks.
Re: Break lines
« Reply #11 on: April 09, 2025, 09:55:33 AM »
 You can also use a banjo bolt at the M/C with a switch built into it. That's how I did my double disc conversion with direct lines.
Offline Nol_one99
Re: Break lines
« Reply #12 on: April 09, 2025, 10:08:32 AM »
I definitely plan to restore the caliper this year but I’m going to hold off for a bit as the one I got is doing pretty good still. I did order the swivel head so hopefully that doesn’t leak haha. But I’ll be sure to keep an eye out for that as you’re right that is a possible leak spot.
And I’m going to be honest I think I’ve been spelling brakes wrong for as long as I’ve been spelling brakes. Thank you haha!
Re: Break lines
« Reply #13 on: April 09, 2025, 10:10:46 AM »
Well if you dont get your brakes right you could break your neck
Offline Nol_one99
Re: Break lines
« Reply #14 on: April 09, 2025, 10:12:33 AM »
Oh I completely agree. I’m plan on being safe with it. I’ll make sure that it’s not leaking before I ride and I know for sure the calipers are doing good for now so.
Re: Break lines
« Reply #15 on: April 10, 2025, 08:24:41 AM »
Good one Bry!!
