Author Topic: Flasher relay - where to source  (Read 774 times)
Offline Cevan
« on: May 17, 2025, 05:34:09 PM »
Fairly certain the directional relay on my 500/4 is bad.  For the heck of it, I swapped in the relay from my CT70 and when I hit the directional switch, the directionals light up but no blinking.  The directional indicator light also lights up.   I know the 70 is 6 volts so I wasn’t sure what would happen.
Where should get get a new relay from?  I found these:
https://www.powersportsdiscount.com/oemparts/p/honda/38300-292-670/relay-assy-turn-signal-142-12v
https://www.common-motor.com/honda-turn-signal-relay
https://www.partzilla.com/product/honda/38300-292-670
1972 CB500/4
1974 CT70
Re: Flasher relay - where to source
« Reply #1 on: May 17, 2025, 06:40:35 PM »
I bought a 2-wire electronic unit fro O'Reilley Auto (sp?) for my 750. It works fine. :)
« Reply #2 on: May 17, 2025, 09:41:14 PM »
use electronic,soon as you hit the button they light up no delay,last forever.
Offline Cevan
« Reply #3 on: May 18, 2025, 02:48:28 AM »
Do these electronic units use the unused ground wire in the panel?  Not sure what makes it “electronic.”
« Last Edit: May 18, 2025, 02:50:02 AM by Cevan »
1972 CB500/4
1974 CT70
Offline CycleRanger
  • No comment about being an
« Reply #4 on: May 18, 2025, 07:37:11 AM »
I'm pretty sure I used an EP35 flasher relay on my bike.
It's three prong so it uses the ground wire.
But as HM mentioned, they make two wire relays as well.
The electronic flasher uses a solid state relay. The original flasher uses a bi-metal strip.
« Last Edit: May 18, 2025, 07:38:58 AM by CycleRanger »
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #5 on: May 18, 2025, 07:43:18 AM »
These work well on our bikes and they clip on to the factory bracket. And they are only $8.00
https://ebay.us/m/IGabZg
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #6 on: May 18, 2025, 07:49:31 AM »
If you ever switch to LED turn signals the electronic flasher will be a must-do.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Nurse Julie
« Reply #7 on: May 19, 2025, 02:19:18 PM »
Just buy a 2 prong flasher unit and leave the green earth wire unattached.
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #8 on: May 19, 2025, 08:40:04 PM »
I first used a cheap flasher relay for old cars. Fitted like the original CB750.
It stopped work after a few years. Next from Yamiya. 3 connections, only 2 needed to connect.
Offline Cevan
« Reply #9 on: May 20, 2025, 03:32:47 AM »
Thanks for the input.  I ordered the one Ozzy recommended.  Now if I could only get Delkevic to send me an exhaust I could ride the bike.
1972 CB500/4
1974 CT70
