Author Topic: Bugabeetle's Budget Build (1970 CB750)  (Read 11566 times)
Offline Bugabeetle
« on: May 25, 2025, 09:32:24 AM »
Hello
I’m a 24-year-old college student from NYC. I’ve been riding for about 3 years now and have owned a few bikes along the way:
2005 Kawasaki ZZR600
1985 Honda Rebel 250
2005 Suzuki SV650S
Nothing too crazy, just solid bikes that got me deeper into riding.
Like a lot of people, I’ve spent way too much time watching videos of people bringing old, dead bikes back to life. I’ve always thought it looked fun. Taking something forgotten and turning it into something you actually want to ride. I told myself that if I ever did it, I wanted it to be a bike that I’d enjoy riding when it’s done.
I kept seeing café racer builds online and the Honda CBs kept popping up. So when I found a 1971 CB750 for $500, I figured this was my shot. It’s rough. Very rough. But it’s all there. Mostly.
Since I’m a college student with limited time and a very limited budget, this build isn’t going to be a full nut-and-bolt restoration. It’s going to be as clean and functional as I can make it. I’m not chasing perfection. I just want something that’s mine, something I’ve touched every bolt on, and something that’ll put a smile on my face when I finally fire it up.
I’ve only done the basics up until now. Oil changes, brakes, filters. This is my first real build. I’m learning as I go. I’ll make mistakes. I’ll ask dumb questions.
More than anything, I’m chasing that high. Sitting in class or at work, thinking about a problem with the bike, and suddenly something clicks. That lightbulb moment. You can’t wait to get home, roll up your sleeves, and test it out. And when it works? That feeling is unbeatable. It’s addictive. Nostalgic even.
So that’s where I’m starting. I’ll post updates here along the way. Maybe something I learn (or screw up) will help you out too.
« Last Edit: May 25, 2025, 08:48:41 PM by Bugabeetle »
Bugabeetle
Online newday777
Re: Bugabeetle's Budget 1971 CB750 Build
« Reply #1 on: May 25, 2025, 09:56:35 AM »
Looking forward to seeing pictures of it before and going through it.
Stu
My current rides
Prior bikes....
Offline Bugabeetle
Re: Bugabeetle's Budget Build (1971 CB750)
« Reply #2 on: May 25, 2025, 08:45:22 PM »
That was a long drive.
Here's some pictures. About to have some headache....I mean fun.
According to my amazing research skills, my bike is a 1970 model-year Honda CB750 K0, built in August 1970. The engine (CB750E-1022435) is from an earlier 1969 run, but still correct for the K0 series.
That being said....if you look at the pictures, a lot of wires are cut.
Time to look for the wiring diagram.
Also, I have to change the title now. LOL.
« Last Edit: May 25, 2025, 08:48:35 PM by Bugabeetle »
Bugabeetle
Re: Bugabeetle's Budget Build (1970 CB750)
« Reply #3 on: May 25, 2025, 08:59:52 PM »
The front forks and brake caliper are K3-K6.
Online newday777
« Reply #4 on: May 25, 2025, 09:07:52 PM »
You do, per the numbers, have a K1 frame, K0 motor and oil tank, K3 gauges and forks, and a K3+ taillight.
Stu
My current rides
Prior bikes....
Offline Bugabeetle
« Reply #5 on: May 25, 2025, 09:26:59 PM »
Ok. I see it. I just went through a quick dive with Google Images. I'm comparing it with some 1970 stock pictures.
The tail light is different. The circle?
The forks. I don't really see it. Is it the color of the top?
The gauge. Is it the white rev limiter? Also, the 4 lights?
I guess it doesn't really matter since they're all the same.
Time to simplify this wiring diagram so I can try and get the engine started. I'll post my drawings here.
Bugabeetle
Online newday777
« Reply #6 on: May 26, 2025, 03:35:07 AM »
It doesn't really matter with your bike that it has bitza parts from different years unless you plan to fully restore it to original. Enjoy it as it got to you. You definitely have a project bike.
As to the front end, they have different parts when you go to order parts for it, seals are different part numbers, and other internal parts, so we are just letting you know that you will run into some differences, even in the motor parts. Have fun with it going through it.
« Last Edit: May 26, 2025, 03:39:38 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: May 26, 2025, 06:12:01 AM »
Lot’s of work there! Definitely jumping into the deep end. Good luck and we’ll be happy to help out…….
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: May 26, 2025, 06:13:55 AM »
Need a set of carbs? I’ve got lots extra. Check my ads in “For Sale” section.
« Reply #9 on: May 26, 2025, 07:55:33 AM »
The caliper mounts on the lower fork legs are different. The early style is on the left, and the later style is on the right.
« Reply #10 on: May 26, 2025, 09:21:52 AM »
 The best/worst thing about the CB750 single cam bikes is the interchangeability.
  The K0 gauges have the indicator lights in them and plastic housings, the K1 have the lights in them with metal housings and the K2 up have the indicator lights in a console like yours and retain the unicorn top triple tree. K3-K6 gages look like yours. No matter, they all work fine.
  My plan is always to get it running and safely riding first.
Offline Bugabeetle
« Reply #11 on: May 27, 2025, 11:07:30 PM »
Update: That was painful. I stripped three screws and had to buy a bolt extractor from Home Depot. After three hours, I finally got the starter motor out. I connected it to a battery, but it doesn't spin. Nothing at all.
So I took it upstairs and opened it. I'm guessing those metal blocks are supposed to touch the copper? It's stuck. Too much oil. I COULD clean it but I'd prefer something new. Is it this one?
https://www.amazon.com/dp/B00PKI8GJY?psc=1&ref_=cm_sw_r_cp_ud_ct_DMQ70G5B1F50A4MWEQX4
« Last Edit: May 27, 2025, 11:10:09 PM by Bugabeetle »
Bugabeetle
Offline Sw1ssdude
« Reply #12 on: May 28, 2025, 01:37:48 AM »
i'd Try to service the starter. they are as solid as a brick. those metal blocks are carbon brushes, they are supposed to conduct electricity from the static parts to the spinny parts. they wear out over time, so they are springloaded with hairclip springs which press them onto the copper (the commutator). under the grime you will see that the commutator has many segments, with isolator in between. as the rotor spins, the  brushes touch the various segments, which generate the magnetic field in the rotor, which have the rotor spinning in the first place. its basically a 'rotary switch'.
your stator looks so grimy because all the carbon dust from the brushes. if you look closely you'll find leads attached to the carbon brushes. one of the connectors is isolated, one goes to bare metal. undo them, then you can remove the springs and slide out the brushes. clean the brushes with something non-oily, like brake cleaner or isoproyl acohol. the rest of the armature (the part that holds your brushes) you can soak in fuel or ultrasonic and clean it with a old tooth brush.
the bushings (at least my Honda CB250G Starter had bushings) on both ends of the case are made from Oilite, a porous brass which can wick up oil. you can remove them with the ominous 'bread trick', or heat up the case and shake them out, but mostly, reoiling is good enough.
The stator coils can be removed as well, but i'd try not to. its a hassle getting it back together again. try cleaning with brake clean, and maybe scotchbrite the anchors (metal inserts around which the copper coils are wound), then dust off.
on the business end of the starter there is a planetary gear (at least there was one on my starter). and a paper gasket which most likely will tear if you open that end (which you want to do if you want to remove the rotor). clean and regrease with fresh grease.
the commutator will have wear marks, from the constant friction of the brushes, and will have black carbon embedded in the copper. Clean the surface with scotchbrite to a nice shiny copper color. ideally, chuck the rotor into a lathe and skim off the commutator, but scotchbriting will get you far. clean the rotor anchors as well (rotor and stator move very closely to each other, any rust or dirt inside the casing can cause the rotor to bind up).
replace the carbon brushes with new ones, or reuse the old ones if they are still 1/2 inch or longer. make sure they slide up and down freely (if you ever watched a youtube-'will-it-run?'-video where the car DIDNT start and the youtuber hits the starter with the hammer, he does so to wiggle the stuck brushes free...)
reassemble in reverse order... now you have a starter that will last you another 50 years...
some visual support for the task at hand:
It's not a big motorcycle, just a groovy little motorbike...
Offline Sw1ssdude
« Reply #13 on: May 28, 2025, 01:47:09 AM »
i just rewatched the video, and i forgot about the shims. And the clocking of the housing.
keep that in mind, and you'll do great.
for the screws: get yourself a decent VESSEL JIS Screwdriver set. Japanese Philips are NOT Philips, they are Japanese industrial Standard (JIS). you can tell by the dot or crossmark on top of the screw head.
also: pick the screwheads clean from oil and grime before trying to undo them. toothpick, awl, or one of those miserable dentist hooks they use to poke your gums until they bleed, will do.
if you use Philips screwdrivers in dirty JIS screws, you'll gonna have a bad time....
Offline CB_Jeff
« Reply #14 on: May 28, 2025, 02:29:51 AM »
Agreed on getting a set of JIS screwdrivers, it will make working on this bike better.
Online newday777
« Reply #15 on: May 28, 2025, 03:33:06 AM »
Well said ssdude.
I've cleaned out several 82/83 1100 goldwing starters that are similar in design internally and are very stout. Cleaning and fresh grease should do the trick to get it working usually.
That kit from your link Buga says it should fit/work, 69-80, though the one review said the brush holder didn't fit so you'd just use the brushes if yours are badly worn past 1/2 way, but by then the commentator might be worn badly, not flat like it should be. As said clean it up well then take pictures of the brushes and commentator  for us.
Stu
My current rides
Prior bikes....
Online newday777
« Reply #16 on: May 28, 2025, 03:51:29 AM »
So are you Caleb?
Stu
My current rides
Prior bikes....
Offline Sw1ssdude
« Reply #17 on: May 28, 2025, 05:10:26 AM »
So are you Caleb?
Hah, no. i'm from Zurich, not from Houston. But i like the videos he makes at Common Motor Collective.
I am not so sure if grease should be used on Oilite bushings, even though i did too on my last starter, and am regretting it now. i have the impression it might clog all those little pores. But the bike is sold by now...
I found a cool trick on youtube, on how to replenish the Oil in an Oilite bushing. i will do it like this in the future:
Online newday777
« Reply #18 on: May 28, 2025, 05:17:52 AM »
That is a great help to oil the bushings
Stu
My current rides
Prior bikes....
« Reply #19 on: May 28, 2025, 07:17:35 AM »
Agreed on getting a set of JIS screwdrivers...
And a impact driver!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #20 on: May 28, 2025, 07:18:07 AM »
https://www.amazon.com/CB750-book-Putting-Them-Back/dp/B003NTKQTA/ref=sr_1_1?crid=3CMAMIM7I2HO2&dib=eyJ2IjoiMSJ9.e_kpcyvpfVBFe2GJfRAlR5h8Jps-uVYs3mtDKVwAf9nGjHj071QN20LucGBJIEps.Sajy4AST2d5Dv1ndkKa9lVUMGlRjtqhSxEKc6fTeexk&dib_tag=se&keywords=my+cb750+book&qid=1748441552&sprefix=my+cb%2Caps%2C223&sr=8-1
The above link is to Hondaman's book on the bike. It is by far the best tool and you need it. It will save you time, money and frustration. You also need a JIC screwdriver for the screws that look like Phillips head screws, they are different. An impact driver is also needed to get the screws loose
https
://www.amazon.com/Vessel-No-260002-260002/dp/B001WHQH0W/ref=sr_1_11?crid=3E5QPNM2OK3FR&dib=eyJ2IjoiMSJ9.TxplMrsuG3sLm4AFk6x7R7sxELJaVDkmeEGahlB7udFZa9GdjTL-Of2psz-LFTY87vSU3iR2w-9PZ0Tqi8Na_UnRMB9g6u2uSoUJKy6ewHMXw3ZKIW9q6LmixaKwMfhdB27CROZl9UHjGU_1KIxS524102xp5HbEt20A_YX05fX_NVW9BobuqC4HKb5kc-W0bY30EEY93XJO6PzNTj_w7--Ymp_jCrjT2AV5uRXi7qGfmaWdm1AJPZUZlsEtkt-ZvMM2eP2OG-t4fUVSoFNQZDGVjIDbO3pO1R8bokRXUb8.YfskFy4UWnnY0pj6yIN8uxDJTxICkt-KcbhHEI4x4C0&dib_tag=se&keywords=vessel%2Bimpact%2Bscrewdriver%2Bjic&qid=1748441761&sprefix=vessle%2Bimpact%2Bscrewdriver%2Bjic%2Caps%2C184&sr=8-11&th=1
Best of luck
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online newday777
« Reply #21 on: May 28, 2025, 09:30:49 AM »
https
Best of luck
The Amazon link is way more $$$ than ordering the book directly through the Site Sponsors section link to LULU  and there is usually a discount available. Please don't put the Amazon link.
« Last Edit: July 11, 2025, 01:41:03 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline Bugabeetle
« Reply #22 on: May 30, 2025, 11:17:19 PM »
Hello,
Good news first. I managed to fix the starter motor.
Now on to the issue. While cleaning the carburetors, I noticed that one of them is completely different from the other three. On top of that, I’m missing some parts. Three out of four are present, and I suspect the missing parts belong to the different carb.
Could you help me identify the missing components? Ideally, I’d like to complete a full matching set but no money. LOL. Would it still work to run one carb that's different, as long as it’s tuned to match the others?
Thinking about it now, would it be possible to swap the internal components of the different one so that it's the same with the other 3?
I've attached some photos for reference:
In the image with all the carbs laid out near a green bucket and a MacBook, the second carb from the left is the odd one.
In the photo on the green cloth, the second carb’s throttle wheel area looks like it has a tube instead — that might help identify it.
I’d really appreciate any help. My goal is just to get the bike running reliably.
Thank you.
Bugabeetle
Online newday777
« Reply #23 on: May 31, 2025, 02:54:21 AM »
No that won't work that way. That odd carb is off a 1969/1970 K0. There will be carb body numbers on each that you need to see to tell if the hack that did that changed the whole carb body or just the slide.
There's a flat surface on the rack side to find the numbers.
Stu
My current rides
Prior bikes....
Offline Bugabeetle
« Reply #24 on: May 31, 2025, 03:45:12 AM »
So I did some digging and eye scanning on my carbs and carbs online.
The 3 of them are 7A. The one doesn't have any markings or anything.
The cap is thicker. The slide pin is on the other side.
So I figured it'd be cheaper to find a 7A but I only found bodies. I would need to buy other thingimajigies to complete the set.
I did the math. It would have been cheaper to just buy a whole new set and clean that instead of buying a throttle body and other thingimajigies to match the 7A.
The guy I bought the bike from did say he used to hot rod CB750s so I'm guessing he just took a carb from his spare parts and tossed it in the box to make a set.
I bought this.
https://www.ebay.com/itm/305908301084
I guess for now, I'll do the gas tank.
Do I really just punch a pin through that pin to take the cap off? I want to paint it. LOL. Maybe change the gas cap too since it looks horrible.
Thank you newday.
Bugabeetle
