Author Topic: The holy grail of headlights  (Read 3195 times)
Offline Deltarider
  • I'm back
Re: The holy grail of headlights
« Reply #50 on: August 18, 2025, 12:29:53 PM »
I like my incandescent bulbs in brake- and indicatorlights for... safety. The glow on-glow off effect they naturally bring, makes these lights draw more attention, They flame up and out and so are better noticed. Led is not lively at all, it is dead, it switches on in a nanosecond and there's no change in intensity whatsoever. Led maybe good for a taillight, but I even doubt that as LED is hardly noticed from an angle. I have learned my lesson. I almost ran in a bus with led brakelights I had not noticed. This has happened twice. I don't want to become rear ended. I stay with incandescent. I advise to check it out for yourself.
CB500K2-ED Excel black
Offline Mr.D
« Reply #51 on: August 18, 2025, 05:04:19 PM »
I did all my instrument lights, turn signals, and tail light with LEDs from SuperBrightLEDs.com
I'm very happy with them. I think I went with the 1157 Dual Function one (in red) for the tail light; the 1156 27 LED Tower (in amber) for the turn signals; and BA9s 4 LED bulbs (each in the correct color) for the instrument cluster.
I do remember one of the blue's I ordered for the high beam indicator was crazy bright, so I bought another one that's much more reasonable, though I forget which one it was. Anyway, they have a huge selection. Not the easiest website to navigate, but worth a look.
¿Did the red taillight bulb not give you a red lit license plate, lol?
Oh! You're right! I went with the white light!
Did you have problems with the white led creating a washed-out orangey light from the red taillight lens?
No, surprisingly I didn't have that problem at all. It looks great, just like original but brighter. I'm very happy with the amber ones in the turn signals as well.
1977 Honda CB550F
1975 Honda GL1000
1957 Triumph TRW
Offline pickleknuckles
« Reply #52 on: August 18, 2025, 07:56:45 PM »
Same experience here.
Sent from my Pixel 8 Pro using Tapatalk
Offline turin39789
« Reply #53 on: August 19, 2025, 05:00:30 PM »
They have one that is red with some white for the plate, but no experience with them. Has anyone tried this one?
https://www.superbrightleds.com/1157-led-bulb-dual-function-25-led-motorcycle-bulb-1157-19-red-leds-6-white-leds
Offline Nachtderuntoten
« Reply #54 on: August 19, 2025, 06:36:07 PM »
I can totally understand the safety aspect, but i disagree as to the source. LEDs do indeed have instantly on and instantly off capability, unlike incandescents, which, even when off yet are glowing due to leakage current; but the issue is more the light pattern of leds. Based on personal correspondence with Daniel Stern when i was looking for recommendations for leds for my CB750K2, he told me that the light pattern is flawed, stating,
‘The "LED bulbs" now flooding the market (like "HID kits" before them), claiming to convert halogen headlamps, are not a legitimate, safe, effective, or legal product. No matter whose name is on them or what the vendor claims, these are almost all a fraudulent scam. The overwhelming majority of them are not capable of producing the right amounts of light, nor producing it in the right pattern for the lamp's optics to work, let alone work well.’
In reference to taillamps, specifically, he stated (from personal correspondence),
‘As with the central stop light, the other signal lights on the car have to put out the right amounts of light through the right range of angles. The guy way up high in the driver's seat of a semitractor needs to be able to accurately see your brake lights and signals immediately…so does the guy two lanes over with his butt four inches off the ground in thedriver's seat of his Corvette. The difference between bright (brake or turn signal) and dim (park or tail) mode has to be adequate.’
This, i think, is more central to the argument/problem; not to mention that he stated to me the LEDs have ‘droop’ because as the bulb heats its light output dims.
« Reply #55 on: August 19, 2025, 08:37:16 PM »
« Reply #56 on: August 20, 2025, 06:07:49 AM »
Rear LED that work fine
http://forums.sohc4.net/index.php/topic,194645.msg2279191.html#msg2279191
That's about the difference I noticed going from incandescent to LED.
