Author Topic: Heat shrink tubing over carb rubbers?  (Read 3044 times)
Offline Alan F.
Offline newday777
Re: Heat shrink tubing over carb rubbers?
« Reply #1 on: August 11, 2025, 11:08:18 AM »
I saw that over the weekend
Stu
My current rides
Prior bikes....
Offline Kelly E
  • Geriatric Hooligan
« Reply #2 on: August 11, 2025, 02:50:49 PM »
My Carquest in town stocks that stuff in 4' lengths. It has a million uses. Just the other day I used some to fix the black plastic 90° fitting that plugs the valve cover vent line into the bottom of the airbox on my 74' CB 550 K0. It's made from the same plastic as the airbox and is cracked to the elbow on one end.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #3 on: August 11, 2025, 03:55:17 PM »
BHB knows his stuff and is/was a member of this forum.  But still, they call it heat shrink for a reason.  I would expect that heat will continue to shrink it in that application until it tears and fails...but if all you got is torn boots, it ain't gonna hurt to try...
Offline newday777
« Reply #4 on: August 11, 2025, 04:01:38 PM »
I think he said in the video that the marine grade has a layer of glue inside to adhere to the surface.
Stu
My current rides
Prior bikes....
« Reply #5 on: August 11, 2025, 05:02:13 PM »
yeah, I have used the stuff extensively.  If you need to remove it, you just re-heat and it just gets soft again and can be pulled right off.  The glue is like rtv, or hot glue gun glue...designed to be strong but can be cleaned up.  It is fantastic for building harnesses...like what it was intended to do.  Was not meant to repair hoses of any kind.  Could it work?  Maybe?  I am skepticle it will work for any long term on carb boots.
Offline Kelly E
« Reply #6 on: August 11, 2025, 07:41:15 PM »
I have been using it for years. It only shrinks so far, it has a shrinkage rating on the label.
1983 Honda CB 1100F
Offline simon#42
  • liverpool
« Reply #7 on: August 12, 2025, 11:17:21 AM »
i dont see that as a permanent solution to cracked inlet rubbers . just fit new ones and be done with it .
« Reply #8 on: August 12, 2025, 11:19:53 AM »
What he said?  ^^
« Reply #9 on: August 12, 2025, 06:21:55 PM »
Yeah, agreed...but there ares so many bikes where new rubbers is not a viable option because no one makes them.
« Reply #10 on: August 13, 2025, 10:06:05 AM »
Kinda makes one want to start up rubber molding, no?
I've been in a rubber molding plant before: it takes some stamina to get used to the aroma.
« Reply #11 on: August 13, 2025, 11:19:10 AM »
But..but......but.....if you soak in a mixture of acetone, Oil of Wintergreen, nitromethane, baking soda and Betty Crocker frosting in a can (Milk Chocolate, NOT Vanilla) they will be better than new.
Offline spotty
« Reply #12 on: August 13, 2025, 09:37:50 PM »
he specifically said he was using that method as new carb rubbers for CX/GL500's are no longer available, which is as good a reason for setting fire to them as i can think of but he seems to like them, but as with all things motorcycle related there are people out there with a soft spot for them. Rode one once and couldn't wait to get back on my XS250....
i blame Terry
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: August 14, 2025, 05:23:39 AM »
I did something similar to repair a “no longer available” air filter connector tube on an old Honda single a few years ago. Pulled it gently over a piece of of pipe with the correct OD and applied the shrink tube. Looks nice and still in one piece……
Not a best practice, but useful when the options are limited.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #14 on: August 16, 2025, 07:46:54 AM »
Agreed, do it when needed, it's a method of last resort.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline CycleRanger
  • No comment about being an
« Reply #15 on: August 16, 2025, 10:51:53 AM »
Yeah but in what proportions? That's the real secret!  ;D :D ::)
Offline Kelly E
« Reply #16 on: August 16, 2025, 03:18:47 PM »
Without the 99% alcohol/oil of wintergreen mix I would have never gotten the carbs back on my 84' Honda Sabre 700S V4. 8)
1983 Honda CB 1100F
« Reply #17 on: August 17, 2025, 05:57:44 AM »
You haven't lived until you try to reinstall any Honda V4 carbs. I use to replace the insulators as they were actually pretty cheap. I rebuilt 1 Magna 1100 engine.....swore to never do it again and have been true to my word.
I think Honda engineers were heavily into crack during that design period. The gear driven cam designs were much better but the number of special tools and general bull$hit associated with them makes them something to avoid.
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #18 on: August 17, 2025, 06:53:40 AM »
;D ;D ;D ;D ;D ;D ;D
Offline simon#42
  • liverpool
« Reply #19 on: August 17, 2025, 12:55:35 PM »
 i used to think rc30 carbs were hard to fit until i did a set on a rvf400  , never again.
Offline Kelly E
« Reply #20 on: August 17, 2025, 02:48:49 PM »
I've done Sabre carbs 3 or 4 times and that's why I make sure to run it in the winter to keep the carbs clean. A heated shop helps a lot. The 84' VF 1000 Interceptor is much better. The perimeter frame lets the carbs come out the top, it's much easier to do.
1983 Honda CB 1100F
« Reply #21 on: August 17, 2025, 03:09:04 PM »
yeah, I have worked on a 500 interceptor, it was several years ago and brand new OEM boots made it pretty easy to put the carbs back...then I put 12,000 miles on it and it dropped a valve and shattered one piston.  Can't even get aftermarket head gaskets for that engine even if I wanted to dive into the complexity and expense.  Honda engineers were surely smoking crack in 1986.  The bike was fantastic to ride but I can't have my motorcycle heart broken like that again.
Offline Kelly E
« Reply #22 on: August 17, 2025, 07:45:02 PM »
I have two spare motors for the Sabre and the Interceptor 1000 only has 18k miles on it and both bikes run great. The aftermarket rebuild parts were minimal and not only are head gaskets rare so are engine bearings. With the V4 Honda's you take care of them the best way you can. I put 150k miles on my first Sabre so they can last.
1983 Honda CB 1100F
« Reply #23 on: August 18, 2025, 05:37:26 AM »
Almost spit out my coffee.....I'm glad you concur. ;D
« Reply #24 on: August 18, 2025, 05:46:12 AM »
Off subject Simon but did you know or have dealings with Tony Scott? I always enjoyed reading about him in Performance Bikes etc and felt he was a pretty smart fella given his work with the RC-30 and especially the RC-45.
« Last Edit: August 18, 2025, 06:18:57 AM by MRieck »
