Author Topic: Dry Ice Blasting  (Read 404 times)
Offline TideWater2
Dry Ice Blasting
« on: August 22, 2025, 05:20:29 AM »
Has anyone tried dry ice blasting a crusty engine? I have one that has had the heads painted black and most of it is coming off, but the rest of the engine is crusty as well. Just wondered how well it would work. Thanks
3 - 1971 CB750 K1s
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Dry Ice Blasting
« Reply #1 on: August 22, 2025, 07:46:14 AM »
I've never seen it done, there is also baking soda, gentle but effective on stuff that isn't too messed up (I think)
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline pjlogue
« Reply #2 on: August 22, 2025, 03:18:28 PM »
I would use caution on larger sized things that are cast using dry ice as the blast medium.  At -109F it could easily crack a casting due to thermal shock of rapid uneven cooling.
-P.
Offline Flyin900
« Reply #3 on: August 22, 2025, 03:31:48 PM »
Laser cleaning and vapour honing has been my go to in the past. I have a fellow who actually uses the Laser Cleaning first which is a cool process that cleans away all the worst crud. Then he vapour hones the parts as a final process and they are as new, especially good on sand cast items.
Canadian company so it may not be a US option. https://laserclean.ca/
Here is a 1966 CL77 305 cc engine as was done a few years ago as a Covid project.
« Last Edit: August 22, 2025, 03:36:35 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Rayzerman
« Reply #4 on: August 22, 2025, 06:26:12 PM »
Oh now you tell me about the laser.  Kool.  I'd love a soda blaster for finishing up, if only I had a spot to keep it.  Cheap enough...
