Author Topic: us import loom  (Read 1748 times)
Offline steven400/4
  • tyre inspector
  • that nice
us import loom
« on: April 15, 2007, 05:03:44 AM »
hi there i,m a new member i could do with lots of help with getting my indecators working on my cb400/4 year 1978 i can get them all to light up at diffent times but not on the same side and thay dont flash and david silvers says you car,nt get relays any more and i dont know if mine is good thanks
regards steve
ps dont no if you need my email to get intouch with me so here it is steven.hogg@tesco.net
1978 honda 400/4 f2 my baby
Offline Raul CB750K1
Re: us import loom
« Reply #1 on: April 15, 2007, 06:28:15 AM »
It's very difficult to troubleshoot your electrical woes with only the description you give. Forget about what David Silver says, you can use any modern blinker relay. You gotta do one thing first: In the blinker relay, one of the wires is the one that goes to the handlebar switch. Connect it directly to battery +. Now, turn your switch to either side. The indicators should lit -obviously not blink. That way you troubleshoot first your wiring, to make sure all the wiring and bulbs are OK.
When you are don, buy a blinker relay -you will probably need a three-wire one. One of the wires go to battery+, another one to ground and the other to the handlebar switch -the one you previously used to connect to + and troubleshoot the wiring.
Good luck
Raul
Re: us import loom
« Reply #2 on: April 15, 2007, 10:49:53 AM »
Steven,
I like Raul's idea for testing your wiring just make sure your battery is good and it is properly charged. If your battery voltage is too low you probably won't get flashing. You will also want to find a wiring schematic/diagram and check all the connections and grounds to ensure it is hooked up properly. Check your bulbs to see if both filaments are intact if they are double filament bulbs.
« Last Edit: April 15, 2007, 10:52:06 AM by RxmanGriff »
Offline merc2dogs
Re: us import loom
« Reply #3 on: April 15, 2007, 11:08:49 AM »
 Most auto parts carry newer electronic relays that operate off a timer, not a bimetal strip like the old style, with the timer type it doesn't depend on load to flash.
 Most of the ones I've seen are marked as for trailer towing, because they don't flash super fast when the extra lights are hooked up.
 The one in my bike is off the shelf and was a direct fit with no mods.  I went to smaller sigal lights and the original one wouldn't flash.
 Main criteria is toi get one that matches the socket pattern.
Ken.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: us import loom
« Reply #4 on: April 15, 2007, 12:23:56 PM »
Hi Steve.
You said that your 400/4 was an import?  Can you post the frame and engine numbers and maybe some pictures?  That way we can work out what model you have and recommend a manual and wiring diagram.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline 750goes
  • it will live
Re: us import loom
« Reply #5 on: April 15, 2007, 10:52:41 PM »
his posted number is
[cb400f2-1081763]
Offline cadler
Re: us import loom
« Reply #6 on: April 16, 2007, 06:48:58 AM »
Keep in mind if your battery is low the relay will not work or go very slow.
Offline Bodi
Re: us import loom
« Reply #7 on: April 16, 2007, 07:52:59 AM »
If they don't light on the same side then the wiring is connected wrong. The front ones connect in the headlight shell and the rear ones connect under the seat, at the top of the fender. The fronts have 2 filament lamps, the dim one is for a marker light. When the ignition & headlights are on and low beam selected (assuming you have a headlight on/off switch, otherwise with ignition & low beam on) the markers should be on. Setting the turn signal switch turns the marker on the selected side off and the signal (bright filament) on through the flasher. The rear signal also goes on.
So make sure the wiring for all the signals and markers is correct so that the right marker goes out and the right signals go on when you signal right, same for left. Then you can go after the "relay".
As stated, normal auto flashers work fine except for the different shape. If you can find a 3-terminal flasher with power, ground, and load terminals that will work best; there's a green wire hanging loose beside the Honda 2-terminal flasher's mount that is perfect for the ground connection.
