Author Topic: Two pipes in Middle of Carbs  (Read 1276 times)
Offline Stumcf
« on: October 04, 2025, 01:55:10 AM »
Hi Guys, I have a 400-4 and there are two connections in the middle of the carbs. Can you please tell me what hey are and whre they connect to. Thank you.
Offline Deltarider
  • I'm back
Re: Two pipes in Middle of Carbs
« Reply #1 on: October 04, 2025, 02:13:21 AM »
Either for fuel delivery or for venting.
CB500K2-ED Excel black
Offline newday777
« Reply #2 on: October 04, 2025, 02:55:38 AM »
Welcome aboard the forum Stumcf
Are you asking about the circled upward pointing, brass color 3.5mm barbed joints, one on each of #2 & #3 carbs?
Those are the atmosphere vent joints that #329 vent pipes, 3.5mm hose, attach to and generally they go up over the stock airbox to the stillest calm air available between the side covers,  out of the way of water intrusion. I don't have a 400F to show where they go.
Fuel lines are bigger, 5.5mm.
« Last Edit: October 04, 2025, 03:17:59 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline Stumcf
« Reply #3 on: October 04, 2025, 04:58:24 AM »
Yes those are the ones. Thank you for your help
Offline newday777
« Reply #4 on: October 04, 2025, 08:25:45 AM »
You are welcome.
Stu
My current rides
Prior bikes....
Offline Mark1976
« Reply #5 on: October 04, 2025, 08:46:52 AM »
   If ya open the seat, you can look down and see the oval tube that connects the air chamber to the air box, it's offset to the left, the vent hoses go over the air chamber to the right of the oval connector tube, mine reach down to the back of the engine case about midway down.
Start with the end in mind...
Offline Nurse Julie
« Reply #6 on: October 04, 2025, 11:05:00 AM »
Hi. As you're in UK, also consider joining us on the UK forum, there are members that live over you way.
www.sohc.co.uk
Trust me I'm a Nurse, I promise it won't hurt....much
Offline Stumcf
« Reply #7 on: October 05, 2025, 08:06:43 AM »
Just done that, thank you. I have beentrying for a while but the registration process just didn't seem to work, but all done now.
