Author Topic: Turn signal lights  (Read 2527 times)
Offline mikerider
Turn signal lights
« on: October 26, 2025, 09:22:04 PM »
For a 1977 honda cb550f  I am looking to buy  some new lights.  The book says that it takes an A4527 ,  but i don't  see them anywhere.  Any thoughts.
Sent from my SM-S926U using Tapatalk
Offline newday777
Stu
My current rides
Prior bikes....
Offline mikerider
Re: Turn signal lights
« Reply #2 on: October 26, 2025, 09:34:28 PM »
I was thinking of just the bulbs.
Offline newday777
« Reply #3 on: October 27, 2025, 04:30:05 AM »
You should have been specific.
You can get them from Honda on that link too.
Stu
My current rides
Prior bikes....
« Reply #4 on: October 27, 2025, 07:04:20 AM »
Bulbs depend on if you have front running lights(US requirement) if not standard 21 watt single contact if yes 21/5 watt stop tail bulb
Offline mikerider
« Reply #5 on: October 27, 2025, 02:09:46 PM »
Light baulb
So I went down and found some 21/5 watt or 1157ll bulbs at autozone.  Came home to install and they still didn't  fit.  I tried everything to push the light in to no avail.  I actually tore up one Light just fighting with it.
What do I do now?
« Reply #6 on: October 27, 2025, 02:15:43 PM »
Silly question but are you sure it needs the 21/5
Offline mikerider
« Reply #7 on: October 27, 2025, 02:25:25 PM »
Light bulbs
I don't  know maybe I need the 21 watt  bulbs.  I only see one contact in there.
Offline mikerider
« Reply #8 on: October 27, 2025, 07:12:43 PM »
Lite bulbs
I finally  got them in and they work great. 21 watts in the back and 21/5 watts in the front.  Thanks all for help.
Online Don R
« Reply #9 on: October 27, 2025, 09:39:48 PM »
 Be careful wrestling light bulbs, they can break and do nasty things to your fingers.
« Reply #10 on: October 28, 2025, 03:42:36 AM »
Been there, done that Don, usually when removing corroded ones though, especially the poxy 501 capless ones
Offline bomellberg
« Reply #11 on: October 28, 2025, 06:57:37 AM »
If you are ok with replacing your blink relay to a solid state one you will have a lot more bulbs to choose from. No need for 21/5 to get the relay working.
I recently did it on my path to LED bulbs (panel indicators as well).
Offline mikerider
« Reply #12 on: October 29, 2025, 07:52:13 AM »
Where do you get the solid-state ones?
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #13 on: October 29, 2025, 08:11:45 AM »
Here you go!
It will even clip on to your original bracket
https://ebay.us/m/xDy2gK
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #14 on: October 29, 2025, 10:21:27 AM »
Here you go!
I just used that on a 750, works great!
Online Don R
« Reply #15 on: October 29, 2025, 06:06:15 PM »
 I need a four pack of those!
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #16 on: October 29, 2025, 08:38:00 PM »
I have them in most of my bikes. Trouble free and consistent.
The trigger current is very low. you can run any Bulbs including LED's
Offline mikerider
« Reply #17 on: November 11, 2025, 03:28:22 PM »
Really small halogen light baulbs.
I went on Amazon to purchase  my halogen ligt baulbs and when they eventually came they were little tinny baulbs.  How would you ever put them on a 1977 honda cb550f?
Offline piefairy
« Reply #18 on: November 11, 2025, 05:56:33 PM »
What halogen bulbs are you trying to replace?
Offline mikerider
« Reply #19 on: November 11, 2025, 06:37:07 PM »
Turn signal lightaq
Offline piefairy
« Reply #20 on: November 12, 2025, 06:24:24 AM »
« Reply #21 on: November 12, 2025, 06:44:55 AM »
Take a look at #1034 lamps for the dual-filament type instead of the #1157. The #1157 draws nearly 50% more current (or 100% more if it was made in China) on the bright filament, and 25%-50% more power on the lesser one (again, Chinese bulbs, every single one I've tested, drawing more than 2x specifications). I have actually "fixed" ailing CB350F/400F/500/550 bikes' "electrical troubles" before by doing nothing more than removing the Chinese-made turn signal bulbs and taillight lamps and installing Stanley bulbs (from Honda).
Even more of a tip: headlights. Watch the wattage rating of the bulbs, use something equal or less than OEM for best results today. Unless you're planning on lots of night riding in the black countryside, a 35w/35w H4 bulb (and lens) works fine for these bikes, especially the ones smaller than the 750.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #22 on: November 12, 2025, 06:53:00 AM »
A switch to all LED seems like a good idea to limit current draw. We don't have any "smart" features that will complain about blown bulbs if they are led"s.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #23 on: November 12, 2025, 05:00:26 PM »
That's where I'm headed...PeWe has done lots of testing with different LED headlights, I'm looking to his experience for my upcoming CB350F build's lighting. This bike has an alternator with enough power to make a yellow-ish 35w/35w H4 beam, and that's about all, tiny!
Offline mikerider
« Reply #24 on: November 15, 2025, 01:21:27 PM »
Replacd all 2 element turn signal and break light
Now, I want to replace the singal element light i.e. the rear lights.  I don't  know if there's any special lights for the indicator lights i.e dash board lights.
