Author Topic: What is this please  (Read 276 times)
Offline ColinG
What is this please
« on: January 11, 2026, 09:42:19 AM »
I am taking advantage of the time of year to sort out some niggles and I have a question. I have a lot of play on the twist grip when the throttle is closed and trying to figure it out. Between the second and third carb there is a screw with wire suggesing it shouldn't move, The screw does not touch anything. Under the screw there is a piece with a spring each side. What does the screw which does not touch anything do? It is almost like it should thouch the point of the piece below as a stop. Sorry about the basic language I don't know what the bits are called.
Re: What is this please
« Reply #1 on: January 11, 2026, 09:48:37 AM »
Welcome Colin! Which model SOHC are you working on?
Offline ColinG
« Reply #2 on: January 11, 2026, 09:52:08 AM »
1978 CB550 K4
Offline denward17
« Reply #3 on: January 11, 2026, 09:53:00 AM »
Probably part of the choke/fast idle mechanism.
« Reply #4 on: January 11, 2026, 09:56:42 AM »
The play in the twist grip can be reduced by adjusting the cable end to the right of the screw in your pic.
« Reply #5 on: January 11, 2026, 12:01:27 PM »
Do not play with that screw or mechanism, rebuilding is a nightmare
