It looks like the pipe is fitted too deep onto the head spigot.
Angle down the pipe at the rear so pipe can glide on the head spigot without damaging force so the rear will match the hole for the bolt.
My Lotus Root pipes had a good fit on my K6.
The Yamiya No Numbers sit different at the front on my K2 as the same pipes earlier sat on my K6.
Both the No numbers and Lotus root had to sit correct at front to match the rear bolt hole in frame.
When not lining up, no force needed, just angle down at rear and pipe will glide free on the head spigot.
Here when I adjusted Yamiya No Number pipes to make rear bolt to fit the frame thru both pipes.
Boot off, pipe down and adjust at front....
EDIT:
Lotus Root and No Numbers are different pipes.
Lotus Root are very hollow with very fat diffusers. Not much inside the pipes.
Photos show Yamiya Lotus Root and No Numbers.
