Author Topic: front brake diagnosing  (Read 5628 times)
Re: front brake diagnosing
« Reply #50 on: April 03, 2026, 01:33:01 PM »
  Thanks for the lively discussion of caliper rattle. I may have induced rattle when I cleaned and greased the pivot. Some of my bikes have indeed been pressure washed and at least one was left leaned against a clothesline pole for a couple winters before I drug it home.
  OK, the Rat Race K1 with dual 76F calipers still has some drag. If I bump the calipers in a bit, it rolls perfectly. I removed them, cleaned and sanded the sides of the pads and got no relief. I checked my notes and I already cleaned and rebuilt both calipers when I assembled the front end a year or so back. That leads me to the master cyl. The holes in the bottom of the reservoir are both open, fluid is clear.
 What I don't get is any free play in the Magura lever, I replaced it with a stocker and no change. I checked the other running bikes here, the two made in 69 K0's, known to have original M/C's both have freeplay, of a few newer bikes, none have any.
    Well, I remembered that I promised to try every suggestion you guys made so I replaced everything inside the calipers and stole a M/C off my "parted in" CB750 K0. The braided lines are a year old, should still be good and now I can compress the lever and when it returns, the calipers are not dragging.
   The pistons reminded me of a member that had his caliper seals melt and stick to the piston. One had a black ring around it and the other had icky yuck on it but not in a ring.
  My brand X mighty vac made short work of the bleeding process and once again it went so fast it sucked air. Do-over time.
« Last Edit: April 03, 2026, 03:19:02 PM by Don R »
Offline 01Thomas
« Reply #51 on: April 04, 2026, 12:45:15 AM »
Hi Don, what caused the actual issue?
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
« Reply #52 on: April 05, 2026, 10:59:41 PM »
 I think it was bad caliper seal rubber as evidenced by the black rings around the pistons.
  I wrote a longer reply but the site went away before it posted.
Offline BenelliSEI
  • 1969 cb750
« Reply #53 on: April 06, 2026, 06:06:25 AM »
Interesting to hear that happens to you too. Yesterday I wrote a detail response to someone’s question and then it simply evaporated when I hit “post”.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #54 on: April 06, 2026, 08:18:39 AM »
I have not had the Poof effect yet but I imagine it may get to me eventually.
Stuck rubber will certainly mess things up.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #55 on: April 10, 2026, 11:39:12 PM »
 I bought a pair of K&L M/C kits and a new snap ring pliers. So far, the existing M/C is working fine. I got distracted by too many projects, a race car a K4 750 that was in the race trailer and a car body coming in about a month.
« Reply #56 on: Today at 03:49:18 AM »
Only thing i can think of Don is bad seals or bad fluid
