Support the site. Your contributions keep this site running.
Quote from: scottly on March 24, 2026, 08:08:11 PM(If you want to confirm if the voltage drop is indeed the root of your problem the quick-and-dirty way, temporarily disconnect the white regulator wire, jumper it to battery +, and check the battery voltage with the engine running. If it goes up, it means the bullet connectors, stator, and field are OK, and the problem is the voltage drop into the regulator on the black wire.)I did this on a battery that read 12.26V with the bike off. After starting it the battery read at 11.44V and when I revved it to 5k rpm it got to a max of 11.52V. This doesn’t seem like the desired behavior.I also tried another user’s advice and jumped the reg white and reg black wires to each other and revved the bike as well and while I don’t remember the exact numbers, the behavior was similar in that it only went up a max of .07VI also tried measuring amps on the field coil and I got nothing. With my leads directly connected to the green and white wires (that were not connected to the harness) I got 0A for both a/c and d/c. Idk if this is at all right but I thought it was worth mentioning. I did replace the bullet connectors on the white wires because it broke. Do I have a bad field coil?
1977 Honda CB550k3But I was still hopeful maybe that wasn't a huge issue, so I RAN the bike and checked AC voltages. At least two videos have told me that each coil should read:25Vac @ idle and 70Vac @ 5k rpmMy bike, however, reads:~8Vac @ idle and 43Vac @ 5k rpm
