Author Topic: jumpy instrument needles  (Read 1891 times)
Shawn Parker
« on: June 20, 2005, 04:52:33 PM »
Hello,
I've got a '77 750F2.  After riding around for a bit, I often get the tach and speedo needles jumping around.  What's the cause and what can be done?
Shawn Parker
1977 750F2
Offline Bob Wessner
  • "Carbs Suck!"
Re: jumpy instrument needles
« Reply #1 on: June 20, 2005, 05:14:11 PM »
Is this something that just started happening? Did you disconnect them at anytime and perhaps the cables are not seated correctly? Did you lube the cables?
Offline oldbiker
  • I HATE RAIN
« Reply #2 on: June 21, 2005, 02:23:02 AM »
Sounds as though the cables are dry. Remember to lube these cables do not use grease. Grease goes dry and hard and makes the cables jumpy. Use a good oil.
eldar
« Reply #3 on: June 21, 2005, 01:24:07 PM »
Another possibility is that the gauges are dirty and need cleaning and lubing.
There is a resource somewhere that shows how to take the gauges apart. I saw it bofore but dont remember.
I am sure someone else has the source though.
Offline Jonesy
  • Shop Rat
« Reply #4 on: June 21, 2005, 03:07:52 PM »
I think the site you are referring to is: http://www.salocal.com/sohc/tech/speedo/spedo1.htm
eldar
« Reply #5 on: June 21, 2005, 04:42:38 PM »
Yup thats it. I used it and pulled mine apart easily. Just take your time.
