Author Topic: What went wrong........... Fixed  (Read 2430 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« on: April 18, 2007, 01:36:00 pm »
I was thinking of taking the 74 CB550 out of the house and trying to start it for the first time after the rebuild.  Long story short, everything was apart.  I checked the trans before I put the top end on in case I had to take it apart to fix something, work through all gears no problem.  Now I though, hym, maybe I better double check the shifting before its outside.  Now nothing, tried first, nothing, second, only if I pull up and turn the back wheel.  Starting to look like I'm going to have to pull the motor and take the bottom off.
Any ideas what to look out for.  I shouldn't have any problems working on the trans from the bottom should I?
Scratching head James ???
« Last Edit: April 20, 2007, 05:57:15 pm by clarkjh »
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline scondon
  • Mmmm......tasty bugs
Re: What went wrong...........
« Reply #1 on: April 18, 2007, 01:50:55 pm »
     I'm not familiar with the 550 gearbox, but if I try shifting gears a few times on the 750, without the engine running, it stops being able to shift at all until I get the engine running and the clutch engaged(slightly). If you're having to spin the back wheel in order to shift then maybe it's the same on the 550.
     In other words, maybe there is no problem ??? ???
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #2 on: April 18, 2007, 01:58:04 pm »
Due to the design of the transmission, it is difficult or impossible to shift gears unless all the shafts are in motion. Carefully place the bike on the centerstand with the rear wheel off the ground.  With the engine running at idle or slightly above, try to shift up and down through the gears. If this works, a carefull road test is your next step. If this does not work, examine the shifting mechanism before doing any major disassembly. Good luck.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline clarkjh
  • Expert? If only.
« Reply #3 on: April 18, 2007, 02:01:22 pm »
Looks like I might have to convince the wife that I DO need to start the bike in the basement.  It's damn hard working in the cold carport, and a hard push in the back door.
Keep the ideas coming.
James
SOHC/4 #3328
Offline clarkjh
  • Expert? If only.
« Reply #4 on: April 18, 2007, 04:19:29 pm »
Took her outside and she started up :), two carb bowls leaked :(, tranny still not working >:(, looks like she's coming out of the frame and dropping the bottom of the case.
James
SOHC/4 #3328
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #5 on: April 18, 2007, 04:33:08 pm »
Did you run through the clutch adjustment instructions?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline ken736cc
« Reply #6 on: April 18, 2007, 04:38:50 pm »
Do not remove the engine until you have checked the operation of the shift mechanism. This can be done in the frame.
Offline clarkjh
  • Expert? If only.
« Reply #7 on: April 18, 2007, 04:46:15 pm »
Clutch is good.
In behind the clutch basket?  the shift leaver gets full stroke, both down and up, but doesn't seem to be moving anything in the gearbox, except for one shift up then it acts like 4th or 5th gear.
James
SOHC/4 #3328
500four
« Reply #8 on: April 18, 2007, 05:17:14 pm »
you don't have to pull the clutch to get to the shifter mechanism. clutch is on the right. you need to pull the shifter off of the left side, then pull the cover, and the shifting mechanism is right in there.
Offline clarkjh
  • Expert? If only.
« Reply #9 on: April 18, 2007, 05:27:32 pm »
I know that linkage too well, guess I'll pull the clutch basket and remove and reasemble that linkage again, (will be about the 5th time) ???
James
SOHC/4 #3328
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #10 on: April 18, 2007, 05:29:00 pm »
I think with the motor off, you do have to spin the rear tire very slowly for the gears to engage.
Have you ever heard of a CB owner that is selling a parts bike on Ebay say, "I rolled the bike through all the gears and they seem to work".
Sounds familiar???
 But if you did have the engine running, it should have gone into 1st or 2nd.
Sorry I can't be more helpful.
Best of luck
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline clarkjh
  • Expert? If only.
« Reply #11 on: April 18, 2007, 05:45:58 pm »
the first 3 it just didn't work, the 4th it worked so I put the basket on and closed it up, something must have come off when I closed it up.  Will find out when I take it apart again.
James
SOHC/4 #3328
Offline clarkjh
  • Expert? If only.
Re: What went wrong........... Fixed
« Reply #12 on: April 20, 2007, 06:07:56 pm »
Fixed
I had to pull the motor and crack the case.  Seems in my zeal to get the bike running I didn't count the shifts, the big cog, number 19 was backwards.  Flipped it and shifts into all five, although fith seems out a bit, but that might just take a turning gearbox to engage over 60%.
Got everything put back together and took Surly out for a test spin, works slick as snot.  Then I figured out my bads toast, stalled at a stop sign, pushed 1/2 mile to a hill that I could jump start her and took her home before it got dark.  I think she'd pull the front wheel if I wasn't as light in saddle as I am, as it is tires are going to need replaced quite frequently.  She idles at 1100 as smuthe as silk. ;D
Grinning ear to ear.  Gotta love that first ride of the season.
James
SOHC/4 #3328
upperlake04
« Reply #13 on: April 20, 2007, 06:41:18 pm »
 Way to go James.   Nice to read a story with a happy ending  :)
