Author Topic: Repairing a hole in factory pipe  (Read 1128 times)
Offline KB02
« on: April 19, 2007, 04:48:11 AM »
One thing that I have noticed while working on the CB400T, is that one of the pipes has a quarter sized hole in the bottom. The other pipe has some corrosion in the same place. What's the best way to fix a hole like that?
« Last Edit: April 19, 2007, 07:37:15 AM by heffay »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
chrisf
Re: Repairing a whole in factory pipe
« Reply #1 on: April 19, 2007, 06:24:06 AM »
Short of buying a good pipe, you could always weld a patch in and cover it up with exhaust wrap.
--Chris
Offline Raul CB750K1
Re: Repairing a hole in factory pipe
« Reply #2 on: April 19, 2007, 02:22:39 PM »
The generic procedure is to take it to the plater. They will bath it in acid to remove rust and old chrome. Then weld a sheet metal patch and grind the excess to leave it as smooth as you can. Take it back to the plater so they can give it afirst nickel plating. Then, buffing wheel until it's polished, und a last chrome plating.
If they are still available from Honda, it can be cheaper to buy new ones.
Raul
