Author Topic: 71-75 cb550 same frame as 76 cb750f?  (Read 1652 times)
keepitrunin
« on: April 19, 2007, 02:36:11 PM »
can anyone tell me if a 1978 3 point case guard will fit a 1976 cb750f s.s frame?
update question: will  a 71-75 cb550 case guard mounting points be the same as as a '76 cb750f?
« Last Edit: April 20, 2007, 06:46:51 PM by keepitrunin »
Offline mick750F
Re: '78 750f s.s. 3-point case guards?
« Reply #1 on: April 19, 2007, 04:57:37 PM »
 It should fit right up no problem.
Mike
Glosta, MA
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #2 on: April 19, 2007, 05:21:46 PM »
Hey there keepit  yeah you might have to put in longer bolt underneith the one that runs through the frame and engine  I use threaded rod works just fine  god luck seven fifty four ever Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
keepitrunin
Re: 71-75 cb550 same frame as 76 cb750f?
« Reply #3 on: April 20, 2007, 06:52:05 PM »
changed my question at top of post. can anyone help answer this question?
will a 71-75 cb550 engine case guard fit a a 1976 cb750f frame and engine?
Offline Steve F
« Reply #4 on: April 21, 2007, 01:39:06 AM »
Probably not.  The guards are intended to mount (on the 750's that I've seen) to the engine bolts and since they're different.....
Offline mick750F
« Reply #5 on: April 21, 2007, 06:46:11 AM »
  If you're changing your question then I'm changing my answer. ;) Not very likely...
Mike
Glosta, MA
keepitrunin
« Reply #6 on: April 21, 2007, 01:51:48 PM »
thanks alot, there is a set on ebay for a 550 frame. oh well, i'll keep looking or buy the two points from tas motorsports.
