Author Topic: will a 73 CB750 exhaust header fit a 75 CB750F  (Read 1780 times)
qcextreme
« on: June 21, 2005, 06:23:34 AM »
will a 73 CB750   header fit a 75 CB750F
« Last Edit: June 22, 2005, 08:49:13 AM by qcextreme »
Re: will a 73 CB750 header fit a 75 CB750F
« Reply #1 on: June 21, 2005, 09:53:58 AM »
Not directly but yes with abit of work. I believe the 73 has stub pipes that would have to be removed
Offline Lumbee
    • My pics...
« Reply #2 on: June 21, 2005, 04:01:22 PM »
...someone else can chime in, but I thought the F had a larger combustion chamber.  Could this cause piston/valve clearance issues?  Something to look out for...
"I'm not a welder, but I play one on HondaChopper.com"
Offline Clyde
« Reply #3 on: June 21, 2005, 07:40:44 PM »
I have interchanged the exhausts and heads OK. If fitting a 73 header to a 75 F, as  mentioned above you will need to get the stubs as used on the earlier(69-76 K) motors, but they fit no problem. From your listing you are not using a stock pipe anyway, but you may also have to modify the bracket  which supports the muffler to the frame
The 75/76 F has a slightly higher compression ratio due to slightly higher domed pistons in the same combustion chamber. The F2 is different though.
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
