Author Topic: Restoration of a 350 four update: Back from the Dead  (Read 67412 times)
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a 350 four update:7/13/08
« Reply #75 on: July 24, 2008, 05:29:15 PM »
pm sent
Offline hoodellyhoo
  • CB350F
« Reply #76 on: July 29, 2008, 06:41:16 PM »
Well I'm just feeling right proud of myself tonight. I've been trying to think of a way to clean the insides of my brake hoses for a few days and the best I could come up with was shooting a squirt bottle with some sort of cleaning solution down the pipe. But I wanted something with a little more oomph. So then I got the bright idea to use a super soaker. I shot my cleaning solution down the pipe and had bits of crap shooting out the other. Eventually things cleared up and now my hoses are clean. Shot the with compressed air to dry them out.
And you thought a super soaker was just a toy....
Offline hoodellyhoo
  • CB350F
Re: Resurrection of a 350 four update:7/29/08
« Reply #77 on: September 16, 2008, 11:23:11 AM »
Time for an update!
As this story left off I had my master cylinder cleaned and reassembled and my brake hoses cleaned. Next step was to paint my caliper and top triple tree that will one day go on my bike. This was my first time doing any real painting so I wasn't expecting perfection. I shot the parts with a few coats of primer, sanded with 400 grit till things looked nice, and the shot a few coats of gloss black. I guess I didn't sand and prime as well as I thought because I ended up with some "orange peel" effect on the parts. I used the caliper the way it was because it didn't look too bad and I was trying to quick get the bike ready for the VJEMC show. I will redo the triple tree in the future.
Primed
Painted
Since I was doing all this work to the front brake I decided to add new brake pads as well, just for good measure. My brake piston was also pitted so I bought a new phenolic brake piston from whatshisface (can't remember his name) on the board here that sells them.
And so began the caliper assembly. The oem brake pads I bought wouldn't fir into the caliper so I had to grind them down until they fit. I greased them with some kind of stinky brake parts grease from auto zone. Everything went back together just fine. I connected up the brake hose and brake switch so that I could begin bleeding.
For brake fluid I used a generic dot 3. For bleeding I used a vacuum bleeder that my dad bought some time ago. After reading here about all the different methods and theories of brake bleeding I felt confident that I could do it successfully. I tried nearly all of the methods (turning the handlebars different ways, just letting it sit, pumping the brake lever in small increments...yada yada yada). All of these produced bubbles either from the caliper or the small hole in the master cylinder. As time went on I finally got to a point where I wasn't getting any bubbles from the small hole in the MC or the caliper. The problem was that I was getting bubbles from the large hole in the MC. I consulted the forums and found that this was not normal. No matter how many times I pumped the brake lever I would get a continuous stream of large bubbles out of this hole. None of this made sense to me because, according to where the hole is, this would mean that the seal closest to the brake lever was leaking. The thing was, I didn't notice and brake fluid leaking from around the brake lever. Another thing I noticed was that, along with the the bubbles coming out of the hole, I was getting black cloudy fluid. This puzzled me because I know I cleaned everything quite thoroughly so I doubted it was leftover debris in the system. After trying to bleed the system even more I figured I would leave it overnight to see if things improved.
The next morning, things hadn't improved. But on the plus(?) side, there was a small amount of brake fluid that had leaked onto the floor, so at least I knew what the problem was. So I drained the brake fluid and tore the MC apart again (oh joy!).
On a side note, when I took the MC apart the first time I used a needlenose pliers to pull the rubber boot off the piston. The 35 year old piece of rubber didn't rip or anything so I saved it. When I reassembled the MC I used the new boot that came with the kit. Now when I take the MC apart for the second time the BRAND NEW rubber boot rips apart right away!
So as I am examining the MC parts I notice two things:
1) There was some sort of paint/coating on the MC piston that was coming off of the part and onto my hands, as if the brake fluid was eating it off. It was also black so this was where my cloudy brake fluid was coming from.
2) On the "vertical" section of the piston where the seal closest to the brake lever sits against, there were tiny spots of what seemed like Welding slag. I guess it's just something I missed when I was putting the thing together. That slag must have prevented the seal from doing it's job, thus letting bubbles into the MC and brake fluid out. Also, the outer edges of that seal seemed slightly torn but luckily my MC rebuild kit contained an extra.
Evil slag of doom:
After cleaning things up again, I rebuilt the MC for a second time (doubly joy!). I cleaned up and reused the old MC piston which amazingly did not have any slag stuff on any of the sealing surfaces, or anywhere for that matter. I also cleaned and reused the 35 year old rubber boot that somehow doesn't rip.
Moral of this part of the story: I do not recommend buying the MC rebuild kit from Sirius Consolidated.
I got my MC reassembled at around 1:30 AM the morning of the bike show. I went to bed and woke up at 5AM so I could get things back on the bike and the system bled. I was a man on a mission and there was no way in hell I was missing that show. I bled the brakes as best I could, right up until 10AM when I wanted to leave. I'll admit that my brake lever wasn't perfectly firm, but it was a vast improvement over what it was like before I started messing with it. And guess what else? No more bubbles came out of the big hole in the MC. Imagine that.
Off I went to the bike show. You can read more about it and see pictures I took here:http://forums.sohc4.net/index.php?topic=36939.0
As I was riding to and from the show, my front brake began to squeak. Not too bad, but still there. Unfortunately as time went on the squeaking got worse and I was riding the bike less and less because of it. I had just spent all that time (and money) working on it and I just wasn't in the mood for more trouble shooting. I just wanted to ride and I couldn't. It got so bad that I could hardly use the front brake to maneuver the bike around in my garage because it was so loud.
Fast forward to a week ago. I'm moving back into my house for college and one of my new roomates comes riding in on a fixer upper yamaha 750 genesis. We start talking bikes and this finally gets me the urge to work on my bike so that we could go for a ride sometime.
I searched the forums for ways to stop brake squeal. I tried two different things at first. One was a product called CRC disk brake quiet. It's a thick  substance that you spray on the back of the brake pads that is supposed to dampen any vibrations. Simultaneously I tried another trick which is to cut grooves in the brake pads which is supposed to  change the frequency at which the pads vibrate. Long story short, neither of these worked for me.
Last saturday I decided to try one more trick that I probably should have done a long time ago, greasing the caliper pivot bolt. I was hasty in my wrenching and one of the front fender stays scratched up my paint on the caliper, but oh well. Initial tests were promising because I could now move the bike around in the garage without it squeaking. But as soon as I hoped on the bike to go down my driveway and a quick test ride, the squeak was deffinitely still there.
On sunday I decided enough was enough. I cleaned the crud and rust off of the old brake pads and put those back on. They never did squeak and still don't. They have plenty of pad left on them so I figure I have nothing to worry about. It was interesting to note thought that when handling the pads, the old pads a noticeably softer than the new ones. I wonder if that the way they always were or if they softened some over time. I took a test ride through some drizzle down to Fond Du Lac and back and no squeaks at all. As forum member johnie said to me in an email, it just goes to show the old addage that if it ain't broke, don't fix it.
It's supposed to be a beautiful week and I now I intent to start enjoying the fall riding season.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: Resurrection of a 350 four update:9/16/08
« Reply #78 on: September 16, 2008, 02:53:54 PM »
The orange peel is related to the type of paint (enamel vs. lacquer), not necessarily the surface prep.  They do look nice though.
And good for you for sticking with the mission of getting that front brake working.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline hoodellyhoo
  • CB350F
« Reply #79 on: September 16, 2008, 02:56:28 PM »
Really!? That doesn't compute right in my head. Just goes to show how much I know about paint.
Offline mystic_1
  • 1970 CB750K
« Reply #80 on: September 16, 2008, 03:40:03 PM »
Could also come from applying the paint too thick - the top layer dries and shrinks before the inside does.
mystic_1
- John Augustus Shedd
Offline crazypj
  • I'm brill, me
« Reply #81 on: September 17, 2008, 09:48:17 AM »
Time for an update!
Evil slag of doom:
 That's 'swarf' from the machining process.
It looks like few things happened, the automatic lathe didn't have enough coolant (swarf got hot and friction welded itself into material)
 very bad cleaning of parts ( ie, none) poor quality control ( parts may have been checked for dimensional accuracy , 1 in 5,000 or so?)
PJ
Offline hoodellyhoo
  • CB350F
Re: Restoration of a 350 four update:11/14/08
« Reply #82 on: November 14, 2008, 12:32:54 PM »
Today I got myself a new roomate here at college:
Me and three of my roomates lifted her up the front stairs this afternoon. I'm glad I got her in today because I think it's going to start getting really cold after today.
This kind of marks a turning point in the work I will be doing to this bike. Up until now pretty much every thing I have done has been maintenance work concerned with making the bike as rideable and safe as possible. Now that I've done basically all of that I plan to begin more restoration oriented work. My plan is to work on the bike here at school as much as I can during winter break when I don't have class to worry about.
Here's my to-do list for the next few months:
*Polish the engine cover bits (sprocket cover, alternator cover, carburetor tops and bottoms, etc) and anything else that needs a good shine. I'm planning on Santa bringing me a buffer wheel.
*Install an allen bolt set to replace my chewed up screws.
*Give the bike a thorough cleaning.
*Install my new upper triple tree and grease my steering bearings in the process
*Possibly paint and install a new valve cover (anyone want to donate a good one?) since the area around my tach insert is broken.
*Drop the oil pan and clean the oil pump screen.
And most importantly:
*Clean up my set of original header pipes and install the MIVV exhaust system I shouldn't have bought but couldn't resist.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #83 on: November 14, 2008, 04:34:58 PM »
COOL!  8)
I brought mine home to my new apartment and had it in the kitchen overnight a week ago. Got a pick here somewhere.
Got it back at the farm for winter, but have been pondering putting it in my living room (GF approval pending ;))
Sounds like a good plan. Although I did my restoration while in school, it took a lot of discipline to keep in the books rather than tinkering with the bike :D.
 Matt.
Gallery at:
Offline Tim in Ohio
  • So I got that goin' for me, which is nice.
« Reply #84 on: November 15, 2008, 03:02:45 PM »
Hoodelly,
Enjoy the opportunity to have your new roommate right there in the living room all winter to tinker with.  In my experience, once you make the leap to a roommate that has [*female parts* ;)]... motorcycles inside the living quarters are generally not well tolerated.  Sorry Matt, but I'm thinking that you shold abandon all hope of getting GF approval on that.  ;)
« Last Edit: November 17, 2008, 10:03:32 AM by Tim in Ohio »
1973 Honda CB350  Four
Check out my CB350F resto project...  watch a complete moron build a bike in front of your very eyes!: http://forums.sohc4.net/index.php?topic=38903.0
Offline hoodellyhoo
  • CB350F
« Reply #85 on: December 01, 2008, 08:38:33 PM »
I'm bored so I thought I would add these pics to my thread.
This is the way my bike looked soon after my dad bought the bike in 1996. He paid $600 which might have been a bit high back then but then again it's not like 350f ads were showing up in the paper all the time either. Note the exhaust. I can understand why my dad changed it. My dad says he posted a request for a new exhaust on some website so I wonder if it was an early version of this site? I searched the greenspun forums once but couldn't find it. My dad also thinks that at least one of the tires was the original.
Offline HondanutRider
Re: Restoration of a 350 four update:12/1/08
« Reply #86 on: December 02, 2008, 06:15:52 AM »
Couldn't help but comment on you youngster's concerns about winter roommates at college/university.
Way back in the 1960's, I was attending university and my ride was a Honda 305 SuperHawk.  (BTW I still have that bike, and it runs!)  I roomed with six other students in an old house with seven bedrooms that we rented.  One winter I didn't have a place to store my SuperHawk so she moved into my bedroom to keep warm.  Made a great place to hang my clothes and things.  Whenever we had a party (which was every other week) and if I had the opportunity to chat up someone without my girlfriend/fiancee noticing, it was a really good line to say: "I'll bet you will never guess what I have in my bedroom?"  They were always amazed to see my roommate acting as a clothes hanger!  LOL
P.S.  I have to note that I also still have the same fiancee as my wife.  We share the same bedroom, but not anymore with my collection of bikes!  ...I can hear our daughters and son already saying: "TOO MUCH INFORMATION, DAD!!!"
P.P.S.  I bought caliper repair parts for my CB350F several months ago, directly from Honda Canada.
« Last Edit: December 02, 2008, 06:19:39 AM by HondanutRider »
Offline hoodellyhoo
  • CB350F
« Reply #87 on: December 02, 2008, 08:26:02 AM »
Thanks for the cool story! Glad to hear you hung onto that superhawk. Unfortunately I'm probably about the only student on campus that gives a hoot about old hondas so it's not something I bring up in conversation very often. The silence can be deafening. I would love to keep the bike in my room but there just isn't any room, so for now it sits next to the broken fooseball table.
« Reply #88 on: December 02, 2008, 09:41:55 AM »
"Glad to hear you hung onto that superhawk."  ...heck, the old lady hung onto me all this time too...but she doesn't need to when we ride down the road on my 2003 GoldWing like she used to on the SuperHawk.
Offline hoodellyhoo
  • CB350F
« Reply #89 on: January 25, 2009, 07:21:12 PM »
Nothing too much to report on today. I gave a try at polishing a few things today. Big thanks to forum member "Johnie" for showing me how it's done. I didn't get too far but I couldn't resist throwing them on the bike to see how it looked. I can't wait to see it when it's done. I've also decided to polish my new valve cover, even though it's not original. I like how it looks on Jim's 350 so I'm going to do it too.
Offline Tim in Ohio
« Reply #90 on: February 03, 2009, 06:06:13 AM »
Hoodelly,
What kind of equipment are you using for the polishing.  Show a pic if you can.  Also, I perused your thread from the beginning again...  I think the thread could use more pics of your girlfriend.  In my humble opinion.  ;)
Offline hoodellyhoo
  • CB350F
« Reply #91 on: February 03, 2009, 11:05:32 AM »
Ask and ye shall receive:
This is my little setup (if you can call it that). I'm using a 6" buffer from harbor freight that I got for christmas. I bought the stand from there too (about $25). I had to drill holes in the stand to mount it because it seems like it's made for their grinder and not their buffer. As per Johnie's advice I am using craftsman buffing compounds (red, green, white) and 6" cotton buffing wheels since the ones that come with the buffer aren't that great. I haven't gotten very far at all but I'm pleased so far. I've got the tarp there to catch most of the dust. I was surprised how dirty things get. Make sure you wear a dust mask and eye protection.
For the areas that I can't reach with the buffer, especially on the valve cover, I bought a rotary tool and polishing attachments. I haven't done anything with that yet so I can't say how well it works.
Offline Johnie
« Reply #92 on: February 03, 2009, 12:42:23 PM »
Hoodelly,
Tim...I think hoodle completely ignored your last idea, of which has nothing but honest intent...  ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
« Reply #93 on: February 03, 2009, 04:48:30 PM »
Hoodelly,
You DO know about the babe thread, right? ;D
Offline Johnie
« Reply #94 on: February 03, 2009, 06:03:01 PM »
Ah Trevor...so you were paying attention... ;D  I think they are coming along nicely.
Oshkosh, WI  USA
Offline hoodellyhoo
  • CB350F
« Reply #95 on: February 04, 2009, 04:15:00 PM »
I cleaned up my exhaust flanges today. I used a wire wheel attachment on my rotary tool and it did a pretty decent job on the surface rust. Whatever metal plating is on them, it was rusted through in some places but nothing too bad. All in all it's just one more little detail to help make this bike look better.
Offline Tim in Ohio
Re: Restoration of a 350 four update:2/4/08
« Reply #96 on: February 05, 2009, 08:43:53 PM »
Hoodelly,
Are you satisfied with the quality of the Harbor Freight buffer?  I like their prices, but have been burned by them before on some things.  Other things... ok.  Inexpensive is good, but when I pay ANY amount no matter how small, I get pissed when it turns out to be junk disguised as a tool.  >:(
Offline hoodellyhoo
  • CB350F
« Reply #97 on: February 06, 2009, 08:35:01 AM »
Hoodelly,
I understand your reservations about the HF stuff. Normally I wouldn't bother with anything this big from them, but I figure it's nothing more than an electric motor so there isn't too much they can screw up. I don't really have anything to compare it to but I will say that I am completely satisfied thus far. It has done everythinng I expected it to do without shooting sparks or starting on fire. If you're super concerned about quality then I would maybe pony up for something better but for the guy doing this stuff on a budget, I think it's a good deal. Like I said before, I wouldn't use their buffing wheels but the machine itself is just fine.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #98 on: February 06, 2009, 01:35:41 PM »
.. but I figure it's nothing more than an electric motor so there isn't too much they can screw up. I don't really have anything to compare it to but I will say that I am completely satisfied thus far.
That's about it  :D, the only thing I've seen screwed up on cheap motors is the balancing. We have a cheap bench grinder on the farm that is impossible to do fine work with, but works fine with a buffer wheel on it.
I'd say if it doesn't shock you, and it doesn't vibrate too bad than you've got a good one.
 Matt.
Gallery at:
Offline hoodellyhoo
  • CB350F
« Reply #99 on: February 07, 2009, 04:47:20 PM »
Today I started to work on getting the MIVV exhaust sorted. Unfortunately most of the time was spent trying to figure out which header pipe belonged to which cylinder. Even with my collection of photos and the directions that came with the mufflers, I'm still not 100% I have it right. It also doesn't help that I only had enough room to work on one side of the bike at a time. Oh well, at least I'm working indoors. Hopefully tomorrow I can have all header pipes trimmed and do a complete dry fit of the exhaust. I sure can't wait till spring so I can hear how she sounds through those four pipes :)
